Painting kitchen cu...
[Closed] Painting kitchen cupboards...
[#5632597]
Evening guys,
So i'm giving the kitchen cupboards an upgrade, changed the handles to some s****y silver pieces, and want to paint the wood in a shiny contemporary finish. Thinking cream or black.
eg.
Currently wooden pine, and was about to purchase some Ronseal Cupboard Paint
http://reviews.diy.com/2191-en_gb/9253591/reviews.htm
but the reviews are terrible.
Anyone got any recommendation?
I'm now thinking some kind of primer, with a good satin/eggshell paint (never had much joy with gloss and it discolouring over time) and apply with a roller.
Posted : 24/10/2013 8:15 pm
Plastikote spray paint is excellent and comes in a wide range of colours. I did some melamine wardrobe doors - 2 coats of primer, 2 coats of gloss and for added optional protection 2 coats of clearcoat. 30 minutes between each coat, you should get a kitchen done in a morning.
Not the cheapest mind you, but the result was surprisingly professional!
Posted : 24/10/2013 8:23 pm
I used the cupboard paint and although it's not awful it does chip fairly easily. Went on well and gives a decwnt finish if you prepare the doors well first. Mine was a quick fix though, wouldn't want it for ever.
Posted : 24/10/2013 8:30 pm
6 coats of paint ? sod that !! I would live with the pine and new door handles
Posted : 24/10/2013 8:33 pm
You need to prepare them really well first. Give it a good washing down with sugar soap and don't miss any bits. It's a kitchen so they'll be full of grease. Then sand it all down with fine grade sand paper.
If you skimp on these two parts then you may as well not bother.
You don't need to limit yourself to the likes of Ronseal Cupboard paint as you buy something like Dulux Super Grip Primer and then your choice of a good Eggshell finish in whatever colour you want. Should last you years, done right.
Posted : 24/10/2013 8:35 pm
My wife does Shabby chic furniture and was recently asked to do a kitchen.
As mentioned above, sugar soap to get the grease and dirt off and then a good sand before priming.
She used Farrow & Ball paint at the customers request, the eggshell finish was really good. (worth leaving a few days if you can as it seems to be a bit tacky afterwards for a few days - easy to chip)
She also painted around the corner of the shut lines to reduce the chance of chipping.
It can look really good if you take the time, time will tell how durable it is!
Posted : 24/10/2013 9:03 pm
At last,something I actually know a bit about on here so I don't have to make it up as usual.
Painted dozens of kitchens and also paint all this guy's stuff - kitchens,bedrooms and bathrooms http://matthewstevensjoinery.co.uk/kitchens/
Forget 'cupboard paint' stick with Eggshell as previously mentioned.
If you're going over pine my advice would be ;
Wipe cupboards down using ESP Primer,this gives the paint a chemical bond to stick to.Works really well,I've been back to kitchens I painted 8/9 years ago and it hasn't chipped or peeled at all.
Now straight on with the Eggshell.3 coats for a nice finish,lightly sanding inbetween.I prefer Farrow & Ball ( used to be terrible paint but the water based eggshell is fantastic ), it's quick drying and very low odour.
You could leave it at that but I finish the kitchens with a water based laquer from Morrells,you chose the amount of sheen you want.
Apply the paint with mohair covered foam mini rollers,they don't last long so you'll need at least 2 for a kitchen
This is gold dust,I should be charging for this 😀
Posted : 24/10/2013 9:08 pm
I'm two weeks into painting our cupboards from dark wood to cream. Using Crown cupboard paint. Not having enough room to lay many doors down at once us a means it's a slow process. The finish looks good if yiu use a mini foam roller but its 4 coats for the outside and 3 for the inside. Used sugar soap then a light sand. The paint is very easy to damage for a few days but seams fairly tough aftet that but only time will tell. I may use lacquer if it proves to easy to damage.
Posted : 24/10/2013 9:40 pm
As others have said preparation is the key. Also lots of thin coats are better than a few thick ones. A light sanding between coats may be needed but you have to keep an eye out and feel to see if and dust e.t.c has settled during drying. Thin coats dry quicker so it doe not take that much longer and the difference in finish is between bodge job and pro.
Posted : 24/10/2013 9:55 pm
Supurb advice guys cheers! some real cupboard paint expertise on here!
8)
@sausagefingers some of those kitchens are supurb! love the blue island kitchen.
also where do you reccomend best place to buy the ESP primer, farrow and bell paint, and mohair mini rollers. DIY sheds selection is terrible when I was looking earlier.
Posted : 24/10/2013 11:47 pm
@chorlton sugar soap added to the list!
Posted : 24/10/2013 11:48 pm
@cheers_drive i'm hoping it won't take more than a weekend 😆 Probably over optimistic of me though!
Posted : 24/10/2013 11:50 pm
@sausagefingers - Some fantastic looking stuff on your site there. Really like the overall design and little details.
Posted : 25/10/2013 1:54 am
 bigh
Here's what I always do.
I prepare by using those wet n dry sanding pads dipped in a mild sugarsoap solution, I find the flat Bosch sanding pads the best, wipe of residue and allow to dry.
Cupboard paints are shite as stated above, my favourite primer is Blackfriars problem solving primer. Also stated above is Farrow and Ball eggshell which beats any other water based coating hands down, if I get all shabby chic and distress the surface then i finish with a dead flat water based varnish like J H Ratcliff or polyvine.
You may come across a miracle paint called Annie Sloans chalk paint while searching the web........don't.
Posted : 25/10/2013 6:51 am
A weekend?! Bloody good luck with that 😆
Buy your stuff from a decorators merchant, it'll be cheaper and better quality.
Just to reiterate that's not my website, I just do the painting for him
Also, even when the paint feels dry it will need quite a bit longer to cure properly.
Good luck and gets some pics up
Posted : 25/10/2013 9:58 am
[url= http://www.duluxdecoratorcentre.co.uk/servlet/ProductHandler?code=DDC10317 ]Dulux trade Diamond Eggshell FTW![/url] Avoid F&B oil based like the plague. If you've got a F&B colour in mind I might be able to get the Dulux mixing code...
Cheers,
Jamie
Posted : 25/10/2013 10:08 am
Had our kitchen units painted twice now - once when new and a repaint about 6 years ago.
Repaint was done using F&B eggshell (no top lacquer as we like them matt) and still looks great. That's in a family of 5 with 1 x dog.
Posted : 25/10/2013 10:20 am
@sausage fingers, I've just ordered some estate eggshell in pitch black. Was considering off black too. Any thoughts on best finish 256 vs 57 farrow and bell
Also they recommend dark tones undercoat, do you think this or ESP, which im finding hard to buy locally.
Posted : 25/10/2013 2:59 pm
To be honest you won't see much difference between the two shades once on the cupboards.I've just done a kitchen in off black and it's one of my favourites but I did find it was a bugger for drying which I put down to a lot of pigment in the paint.
The ESP was purely to give the paint a key and to be honest I wouldn't paint a kitchen without it.Whereabouts are you? If you're local I don't mind nipping round and lending you some.Eggshell is perfectly fine to be used as an undercoat so don't buy any extra paint just give it a coat of the black for u/c.
[URL= http://i335.photobucket.com/albums/m453/mickylall/IMG_0193.jp g" target="_blank">http://i335.photobucket.com/albums/m453/mickylall/IMG_0193.jp g"/> [/IMG][/URL]
[URL= http://i335.photobucket.com/albums/m453/mickylall/IMG_0194-1.jp g" target="_blank">http://i335.photobucket.com/albums/m453/mickylall/IMG_0194-1.jp g"/> [/IMG][/URL]
Posted : 25/10/2013 4:25 pm
That one is off black with a 40% sheen laquer.To be honest it looked fine without the laquer but the customer insisted on it.Eggshell is very hard wearing so I wouldn't bother with the laquer if it was my own kitchen.
All the best but forget doing it over a weekend,give yourself at least a day and half per coat after prep
Posted : 25/10/2013 4:32 pm
Cheers! I'm in Manchester so probably too far from you. 🙁
Looking at that pic above (Stunning btw) i'm also tempted by the white colour too 😀
Which white is generally the best finish?
http://www.farrow-ball.com/colours/paint/fcp-category/list
That ESP routine sounds too easy though, ESP then eggshell as the U/c, then normal coats on top, can't wait to crack on with it.
Posted : 25/10/2013 8:09 pm
Heres the sides of the cupboard, melamine?
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_172926_zps8ec3260e.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_172926_zps8ec3260e.jp g"/> [/IMG][/URL]
insides
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_173019_zps4995fa7e.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_173019_zps4995fa7e.jp g"/> [/IMG][/URL]
cupboard doors with the retro handles!
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_173142_zps240a63f0.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_173142_zps240a63f0.jp g"/> [/IMG][/URL]
ps. will this ESP do?
http://www.owatroldirect.co.uk/product/esp-easy-surface-prep/
Posted : 25/10/2013 8:11 pm
Righto,you're not too far.
I can meet up with you and lend you my stuff,I'm in Sunny Burnley.
ESP is perfect for those units,no need for sanding
I'll have a look in my van but I should have enough for what you need.
I'm on the lash tomorrow so if we can sort it out early,all the better 😀
Posted : 25/10/2013 8:39 pm
The kitchen we did had those same handles OP.
They will need a little filler where the pins are that help to hold the backing plate on.
Do it first, then you wont be spoiling your lovely finish later!
Posted : 25/10/2013 9:14 pm
Sent you a mail Mick
@alibongo, handles are now off and much drilling has commenced for new handles! Little pins everywhere 😆
Posted : 25/10/2013 10:03 pm
 grum
*bookmarks thread*
Posted : 25/10/2013 10:55 pm
 DT78
*me too*
Posted : 25/10/2013 11:18 pm
Old handles are off
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_234049_zps950ad9d7.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_234049_zps950ad9d7.jp g"/> [/IMG][/URL]
New handles fitted
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_192718_zpse35ce1ce.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_192718_zpse35ce1ce.jp g"/> [/IMG][/URL]
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_232649_zpsdd5cb924.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_232649_zpsdd5cb924.jp g"/> [/IMG][/URL]
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_192713_zps856e79b5.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131025_192713_zps856e79b5.jp g"/> [/IMG][/URL]
and HUGE thanks to sausagefingers for meeting me early on a drizzly Saturday morning. ESP, mohair rollers, roller, tray and selection of papers. Huge wealth of knowledge and top chap too, really appreciate it 😀
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131026_101706_zps782ac28d.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131026_101706_zps782ac28d.jp g"/> [/IMG][/URL]
Posted : 26/10/2013 10:28 am
Chose the Slipper Satin in the end, looked at a lot of white kitchens and liked the off white.
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_200606_zpscbafcf01.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_200606_zpscbafcf01.jp g"/> [/IMG][/URL]
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/IMG-20131026-WA0028-1_zpsdc750925.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/IMG-20131026-WA0028-1_zpsdc750925.jp g"/> [/IMG][/URL]
ESP went on well
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_101347_zpse72b76c1.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_101347_zpse72b76c1.jp g"/> [/IMG][/URL]
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_102429_zps79fb488b.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_102429_zps79fb488b.jp g"/> [/IMG][/URL]
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_101350_zpsede50040.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_101350_zpsede50040.jp g"/> [/IMG][/URL]
and got the undercoat done, which covered fantastic, although very white and not very slipper satin, but i'm guessing the next few coats will bring the proper off white colour out, along with the drying.
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_200203_zpsc5923a60.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_200203_zpsc5923a60.jp g"/> [/IMG][/URL]
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_180029_zps4dd0a214.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131027_180029_zps4dd0a214.jp g"/> [/IMG][/URL]
Posted : 27/10/2013 11:37 pm
This colour compliments your tiles better than black would have done,
Are you going to paint the insides of the doors?
Posted : 28/10/2013 12:31 am
You have my kitchen! . I have those doors , handles and tiles- and quite like that painted finish 🙂
Posted : 28/10/2013 7:42 am
Or do what the pros do. Find a local spray finisher and get him to do a proper job. Mine charges me around £1.50 sq ft. I have to get the doors to him in a prepped state though.
You will get a perfect finish and proper hard wearing paint.
You will also avoid trashing you cupboard doors and getting everything covered in paint (and pissing off your beloved)
Posted : 28/10/2013 9:49 am
restless - Member
wasn't going to at first, but think it will give it the finished look.
cheers! how old is your kitchen? This came with the house and I always thought it was circa 2003 😆
Posted : 28/10/2013 11:39 pm
2nd coat, eggshell finish looking better, pretty impressive paint
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/IMG-20131028-WA0028_zps4deb0434.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/IMG-20131028-WA0028_zps4deb0434.jp g"/> [/IMG][/URL]
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131028_185146_zps3b644ce2.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131028_185146_zps3b644ce2.jp g"/> [/IMG][/URL]
Posted : 29/10/2013 12:14 am
Looks a good job.
Posted : 29/10/2013 12:22 am
£12 for pack of x5 from Wickes, really add that new kitchen soft close door action 😆
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131029_225205_zps4208b49c.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131029_225205_zps4208b49c.jp g"/> [/IMG][/URL]
[URL= http://i911.photobucket.com/albums/ac320/cruzcampo77/20131029_225224_zps5442cb16.jp g" target="_blank">http://i911.photobucket.com/albums/ac320/cruzcampo77/20131029_225224_zps5442cb16.jp g"/> [/IMG][/URL]
Posted : 30/10/2013 12:21 am
I love those soft close thingies, must get some for when I paint my kitchen cupboard doors very soon. Just got to find some of that ESP stuff - it does work on melamine doors doesn't it?
Posted : 31/10/2013 12:10 pm
Blimey - we've got the same kitchen, but ours looks to be in a darker shade.
I have considered doing this, but wasn't sure how modern handles would look on an older style door. Looks very nice though so far.
Interesting that with the right primer you don't need to sand.
Did you paint the doors with them in place? Or removed?
Posted : 31/10/2013 12:35 pm
@ lady gresley
The sides of my cabinets are melamine I think, really smooth surface with a fake effect wood plastic coating. ESP is perfect for this, it lets you paint on glass too
http://www.owatrol.com/index.php?langue=en&page=produits-esp
Posted : 31/10/2013 2:29 pm
@ stumpy have you got the same hob hood too? Thats the bit I wasnt sure about painting white, but it looks pretty good.
Painted doors in situ, less faff, can dry all round too without propping up, and only build up of paint is at the base of door pattern which can easily be brushed out. Reckon flat they'd be more build up, in grooves. Sausagefingers who paints these regular leaves in situ too.
Posted : 31/10/2013 2:39 pm
cruzcampo - Member
If not the same, it looks bloody similar (from memory). I'll be digging this thread out this evening when i get home & having a look. Although I won't be showing it to her indoors until I've assessed how much work it will entail as we want to replace the kitchen in the next year or so. It would only be an interim spruce-up so don't want to do it, if it's too much work.
Posted : 31/10/2013 3:59 pm
Not sure how I've missed these updates,some really good progress there Steve.
Looks like a nice finish on the paint,I think you'll get a lot of job satisfaction out of it when completed.Those soft close hinges are a nice touch.
Keep the pics coming,for the cost it's going to look very good indeed
Posted : 31/10/2013 4:06 pm
Wow you're motoring along. I've been doing mine for 4 weeks almost and I'm not even working at the moment. I think I'm paying for using cupboard paint which needs 4 coats, the wood was a lot darker than yours thoughthink I'll get some soft close thingies too.
Posted : 31/10/2013 4:38 pm
cruzcampo - Member
I've put a few handles on to assess finished look, and I don't think i'll want a new kitchen once its had the next coat, its looking pretty nice! 😯 The missus gives it the thumbs up too 😆
Posted : 31/10/2013 7:40 pm
sausagefingers - Member
Huge job satisfaction I reckon! Decorating is one of those things I always put off, but i'm quite enjoying this now i'm into it, helped by the fact its raining all the time and the trails now = gravy 😆
That ESP stuff is like liquid gold! 8)
Posted : 31/10/2013 7:42 pm
