Pace RC36 Stealth S...
[Closed] Pace RC36 Stealth Setup
[#199404]
What grease can i put in the g-spot? Will a normal grease gun fit or do i need a pace specific one?
Cheers.
Posted : 08/01/2009 1:27 pm
i use the pace stuff
any grease gun for similar fitting will work (ie manitou fork one etc)
Posted : 08/01/2009 1:30 pm
Cheers mate. I don't suppose you have any advice on setting the fork up? Just doesn't seem as easy as my Vanillas!
Posted : 08/01/2009 1:41 pm
can i use finish line teflon grease?
Posted : 08/01/2009 1:52 pm
don't they only have preload and rebound?
Posted : 08/01/2009 2:00 pm
Wasn't sure what to do with the dials on the pace. The 2 dial system on the vanilas was piss easy to set up. The pace are a bit of a headscratch.
Posted : 08/01/2009 2:04 pm
without them in front of me, i think they have rebound at the top of the RH leg and preload under the top cap of the LH leg
set sag to what you require
then set rebound until they are bouncy enough for you 🙂
Posted : 08/01/2009 2:11 pm
Top cap? That'll be where i've gone wrong!
So would you say it's worth bothering with Pace specific grease?
Thanks for your help.
Posted : 08/01/2009 2:15 pm
no idea, i've only used the pace grease!
i'd also advise keeping an eye on the seals, mine frequebtly failed until i had the 'extreme conditions' seals put in, the same with the wifes non stealth versions
Posted : 08/01/2009 2:21 pm
Cheers again.
Posted : 08/01/2009 2:24 pm
I had the wet weather seals installed on mine and used Manitou grease with no problems. Only needed one service in 2 years' use.
Can't help with the set up as I flogged them a couple of years back, so can't remember where the dials were.
Posted : 08/01/2009 4:12 pm
For Pace RC 7 Grease (or Lard to give it its technical name)
Call Tim at Fork English
Posted : 09/01/2009 8:37 pm
A thumbs up for this fella...did a great job on my forks and to top it off he sounds a top bloke !
Posted : 09/01/2009 8:53 pm
