I noticed on a ride today i have lost the rabbit pin on my Revs. Just left with the red allen key bolt thing.
Can you get a replacement and is it a problem for the operation of the forks?
Thanks
Posted : 31/05/2014 6:55 pm
Posted : 31/05/2014 6:57 pm
Yes, thanks Jamie. Is it a problem its not in the forks or am i just stuck in what ever the last setting was?
i have another set of rockshox forks. if i was being really cheap could i switch the pin over?
Thanks.
Posted : 31/05/2014 7:01 pm
Just swap the adjuster between them, and spend the £16 on beer.
Posted : 31/05/2014 7:35 pm
Top man!
Posted : 31/05/2014 9:35 pm
Or better yet, remove the other one too and only put it back if you actually need to adjust the rebound (or throw it away and just use a 4mm allen key instead). They're bound to fall off sooner or later if you ride with them off road anyway.
Posted : 31/05/2014 9:38 pm
