Well my decks have been under the bed for 3 years now and haven't bought any vinyl in that time so last night I went and treated myself to a dj controller for my laptop (called the mixtrack pro)
I was never an amazing dj but when first got my decks I locked myself in my room until I could beatmatch and be able to distinguish between the track in my ear and one on the speaker and ride the pitch to get it in sync
I hooked this up last night and it took me a fair while to get used to the controls and platter. Seems i've got a lot to learn about hot cues, loopin, effects, beatgridding? it's a whole new world. I purposely haven't pressed the 'sync' button,
I installed serato intro DJ but the package came with traktor LE as well. Overall i'm blown away by what it can do and i've always loved spinning some tunes.
So any tips from dj's
If it gan't make David Guetta eff off it's not the kind of DJ controller I'm after.
That is officially BAD ASS
How much and where from? I need one...
*chuckles*
[url= http://www.chemical-records.co.uk/sc/servlet/Info?exs_lnsrc=google&exs_lnty=products&Track=MIXTRACKPRO ]Numark Mixtrack Pro[/url]
If I get one two could we get Dave Lee Travis and Simon Bates to have a fight to the death?
I've got one of these, been using it to gig with the last year or so. Serato is OK but a bit basic. A copy of Traktor is what you really want.
DJ Tech Tools have a lot of tips about how bes to use Traktor and the best way to utalise the effects and things. Controllerism is a different skill to normal djing imo. TBH, I do use the SYNC button, it just makes life easier. I can beat match and stuff manually, but its less faff with sync, and you still need to check the phase and what not by ear, but it free's up a bit of time to play with the effects and get creative.
I ended up buying another midi controller for effect controllin, looping and hot cueing because the Numark didnt have enough buttons... Or thats how I rationalised it, its really just because its the coolest midi controller i've come across:
awesome.. Did you make the transition from vinyl?
Doesn't look like they do an upgrade from LE 2 to traktor pro 2.
I thought i'd pick it up fairly easy but I was struggling with keeping the tunes beatmatched. Perhaps i'm out of practice but also the pitch seems really sensitive
It's my birthday soon and I really don't want one, honest!
Some hints may need to be dropped about the house soon I think 🙂
awesome.. Did you make the transition from vinyl?Doesn't look like they do an upgrade from LE 2 to traktor pro 2.
Learned on CDJ's so not quite the same jump as it would of been from vinyl.
Yeah, I just bought TP2 outright as it wasnt super expensive (compared to something like Virtual DJ) and as I'm getting paid it was an investment.
The pitch is quite sensitive so if you're doing things totally manually you do need to be quite active on the platters to keep things in sync. You'll get used to it.
looks like you're going to be in for a tricky disco.
DJ Tech Tools
I went out to see them and collect my VCI when I was on business in the area. Cracking guys and fantastic kit 🙂
So how is traktor better than serato? I really have no clue, i installed serato intro last night and it 'seemed' to look the same as traktor. Does traktor handle things differently?
Yea.. i did the typical thing of not reading the manual and diving straight in. I kept pressing the scratch button on and off so i could switch between dropping a beat in and speeding up the platter.. until i realised you could just do this by touching the side 😯
Do you do a lot of prep work beforehand on all your tracks?
Quick question whatnobeer have you got an external hardrive with all your tunes are using an external? (if so any recommendations?)
I just found the free version of Serato to be a bit basic and lacking in depth with regards to how effects, looping etc were controlled. The payed for version might be better?
Traktor has a huge amount of depth and takes quite a bit of learning to get the most out of (and I cant honestly say I know it that well, but enough to do what I want).
I'll make sure they're all loaded in to Traktor in advance and I'll usually set in/out cues and any hot cues for the track before I play a set. The software is so good now that usually the beatgrids are fine and don't need touched, I find it easy enough to correct a beat drift on the platters anyway, so its not a problem if things are 100% perfect all the time.
Nah, just use the SSD in my Macbook, I find its plenty big enough to hold all my tunes. I do use a NAS at home for storing video and what no though, so its only really my music thats on the laptop. I use a MyBookLive NAS from Western Digital.
Sweet, what is it you do? Or was it just a curiosity trip? Their Midi Fighters controllers are my favourite bit of kit, never mind all of the other stuff they do.
If you're going to buy the full version of Traktor you might as well sell whatever you've got and get the Kontrol S2.
Traktor costs about £60, an S2 is about £400, bit of a change in price brackets....
I use a Native Instruments S4 wi Traktor pro and Native Instruments Maschine for sequencing and sampling on the fly etc. I've used both Serrato and Traktor and in my opinion and every DJ/producer i know (apart from the few who are scratch dj's) much prefer the workflow and layout of Traktor. Get yourself onto [url= http://www.native-instruments.com/forum/forumdisplay.php?f=105 ]The Native Instruments Traktor Forum[/url] as that'll help you with any queries or problems you may have, also check out all the Traktor instructional vids on the NI website as these will open up areas of traktor that you may not be aware of - if you can afford it then NI were doing cheap upgrades to the full version of Traktor - something you may want to explore further if the LE version is feature locked.
Spend some time optimising your laptop to run Traktor, switch off everything that may have an affect on memory usage and dial in your latency as low as possible, make sure your tunes are categorised correctly in itunes, it took me a couple of years in total doing quite a few tunes a day to label correctly 8000+ tunes and add ID3 tags with such info as BPM/Key/Genre/artist/remix artist//label/sub label/artwork etc and imported into Traktor's library and i dunno if you play/mix by "Key" when your DJ'ing but if you do then [url= http://www.mixedinkey.com/?gclid=CK6Q1tOozLQCFczHtAodrGoAqw ]Yakov's - mixed in key software[/url] may be of benefit to yourself as learning what key changes work best with tracks is an easy way to add some genuine polish to your mixes.
Don't think you have to avoid the sync function to be a proper DJ, I know quite a lot of Pro DJ's through booking them for festivals and club nights (darren emmerson/meat katie/elite force/krafty kutz/utah saints/loops of fury/andrew weatherall etc..) and they all laugh at this argument that you have to beatmatch by ear all the time, it's kinda like the rigid/fixed/ss is the only way to ride off road argument put about by luddites and snobs, anyone can learn to beatmatch - it's not hard in the slightest so why hold yourself back? - learn how to fully utilise all the tricks and treats that Traktor has and you'll be a far better DJ than one who stands there in his horsehair shirt fretting and frowning whilst getting that beatmatch perfect, the crowd will have wandered off to another room by this time.
I've been messing about wi "Dj controllers" for 5-6 years now and it was the best thing that could'a happened, as i can remix on the fly and if i route/use the Maschine controller as well it's an absolute hoot and fun to use, there's still a place for my 1210's and hefty record box but i could turn up anywhere that has digital decks running traktor and plug in my USB stick with my traktor logs/tunes and play just as well (or badly depending on your point of view) as i can at home on my personal set up.
Check out [url= http://www.youtube.com/user/ellaskins/videos?view=0 ]ellaskins/dj tutor on you tube[/url], he's got a lot of tips n, tricks for someone new to dj controllers.
Most importantly have fun...there is no right/wrong way to dj, whatever works for yourself is the correct way and if folk are dancing and having fun then that's all that matters, tell the music snobs to buggeroff.
Nah I was just in town for a few meetings (unfortunately my job isn't music related in any way shape or form!) and had ordered one before I flew out, so I picked it up before I caught my flight back home.
Their products are amazing and you can tell it's grown out of passion for what they do rather than trying to develop a niche and make loads of cash.
I've since sold the VCI, but hankering to get something else now 🙂
The Sync argument is so boring, the crowd dont care...
If I had the beans I would get a Traktor Kontrol S4 🙂
It was only because i'd learnt on vinyl that I felt i didn't want the software to do it for me or that beatmatching by ear was an important skill to have.. then again djnig isn't all about beatmatching and like you say.. the crowd don't care.
Like I say i've only played with it for 1 evening and I'm keen to get into the effects, looping and everything else that goes with digital djing. just seems so much more versatile than carrying round all my records.
My tips are...
Convert your MP3's to CBR
Run them all through the same BPM analyser.
Run them all through MP3Gain
Use the ID Tags, genre, artist, etc, makes searching a lot easier.
If you can, add all your cue points/hot starts on your PC to your MP3's. Keep your MP3's organised! I have lost hours organising and re-organising my MP3's.
Looping with MP3's is a lot easier than it was with a sampler! MP3's do offer the ability to do off the cuff mixes/re-mixes without having to plan them in advance.
I use my MP3 decks just as much as my 1210's, they are totally difference but both are amazing.. I blame the DJ. 😉
[i]Just read somafunks post.. yeah that![/i]
It's an amalgamation of three things i guess,
It is in "kinda' reference to the [url= http://www.somarecords.com/ ]Soma[/url] label, a close friend of mine that Dj'd and set-up the [url= http://www.soundhaus.co.uk/ ]Soundhaus in Glasgow[/url] introduced me to Stuart and Orde from Soma and the emerging techno scene back in the 90's in the city and one thing led to another over the intervening years n' club nights, introductions etc...yadda...yadda and needless to say my preferred label is Soma...for obviously being the #1 label in my opinion.
It's also with reference to Aldous Huxley's - Brave New World and the state sponsored pacifier lifestyle supplement that is "Soma"
"..there is always soma, delicious soma, half a gramme for a half-holiday, a gramme for a week-end, two grammes for a trip to the gorgeous East, three for a dark eternity on the moon..."
And the final reference combines the effect we usually felt on a monday and tuesday after a heavy weekend of clubbing/partying/socialising with all that that entailed at the time .....
"Christ.... i'm in a right somafunk of a mood today"
Meaning that we were feeling rather under the weather and below par or not exactly firing on all cylinders due to the weekends excess.
Good times though.....in fact possibly the best of times as a friday night used to slide into a saturday afternoon drinking session wi all sorts of folk followed by saturday night hopping from club to party to bar and back to club and drip...drip...drip into a Sunday morning as we attempted to gather any energy left for a sunday night Sub-Club session wi twitch n' wilkes at Optimo.
Of course i'm much more sober and sensible these days 😉 , i turned down all invitations to new year partys in the city as i wanted to start this new-year feeling fresh n' normal and i headed out on the bike round kirroughtree instead - bliss!.
However it is my birthday towards the end of january so a 3 day session up in Glasgow to catch up wi folk is organised and set in motion already.....i'll recover sometime in february from that one i expect.
It is in "kinda' reference to the Soma label, a close friend of mine that Dj'd and set-up the Soundhaus in Glasgow introduced me to Stuart and Orde from Soma and the emerging techno scene back in the 90's in the city and one thing led to another over the intervening years n' club nights, introductions etc...yadda...yadda and needless to say my preferred label is Soma...for obviously being the #1 label in my opinion.Good times though.....in fact possibly the best of times as a friday night used to slide into a saturday afternoon drinking session wi all sorts of folk followed by saturday night hopping from club to party to bar and back to club and drip...drip...drip into a Sunday morning as we attempted to gather any energy left for a sunday night Sub-Club session wi twitch n' wilkes at Optimo.
It's highly likely that we know a lot of the same people 🙂
I wasnt having a pop btw, its a great skill being a good DJ, but people struggle to except the world changes & has moved on & there are various ways to go about it now... Obviously some people in the crowd do care, but wholesale, the majority dont, its all about the music!
I'm definitely having a mix after work now!
I'm sure we do peter 😉 , in fact we've prob been at the same parties/houses/aftershows etc as the scene in Glasgow is small enough that everyone knows everyone else or is one person removed at the most.
Shame about the Soundhaus but Bruno has good plans for the resurrection of the "Ideals" of the initial club set-up back in the 90's and a change of name and venue will not do it any harm, i used to love the parties and the crowd at the original soundhaus - the underground atmosphere of the club and anarchic feeling of being able to do whatever you liked as it was a private members club was reminiscent of the scene when it started back in the late 80's early 90's - anything went....within reason of course
. My mate is no longer involved but i'm still in contact wi Bruno so i'll be up for the opening of his new venture in March, if i've recovered from the session at the end of the month..there's quite a few annoyed folk as i didn't turn up for the New Year parties but i'm too old (and wise!) to attempt that sort of excesses anymore.
You've not seen Abletons Push then?
Apart from the fact I dont use Abelton, its not made with Japanese spring loaded arcade buttons, so its not a cool as the midi fighter (IMO of course :P)
OP, I had the same device as pictured (actually, probably an earlier version as mine looks sort of exactly the same but a bit different) and my practical advice would be to be very gentle with the cross-fader and the sliders as they went very crappy very quickly on mine.
so i've been playing with this a bit now. I'm finding i don't get the same buzz I had mixing using sync then i did with beatmatching 2 records together.
Maybe i need to spend more time working out how to change the track live and intruding loops and effects and cuts
Out of interest, people using these controllers do you always use the sync button?
Also.. why does traktor analyse the damn file everytime i load it into a deck. Why can't it do it once so I don't have to wait?
