I've never found the Cutter site particularly user friendly, but have managed.
With the XM-L leds though I can't find how to order an LED board at all.
With the XPGs you go to the CREE LED page, then Cree XPG, then select the XPG Bin you want, then which pcb you want which in my case is an MR11T; easy.
But with the XML, there is no option to purchase them on a board that I can find. There is a link that says "For XML Leds mounted x 3 on 32mm Round Printed Circuit Boards" click here, but that just takes you to pages and pages of "all products"......
I have knackered an XPG board and thought I might as well replace it with an XM-L one and matching optic (which is available on their site), rather than another XPG, seeing as the XML will give me more light.
Any reason to stick with XPG, over XML? I've seen the Deal Extreme threads saying that their new XML light has a very bright centre spot which I am not keen on, but presumably that is down to the optic, rather than the led??
I would suggest you email Troutie or Luminious and see if they can help you out first. They carry a fair few spares of leds I would imagine or atleast point you in the right direction.
Smudge
Cheers Smudge - yeah, I'll do that.
I have e-mailed Cutter too. Will see what sort of response I get.
