how do i change the...
[Closed] how do i change the bearings on superstar switch evo front hub
[#3951566]
help please i have superster switch evo front hub does anybody have and instructions on how to disasemble the front hub please its 20mm bolt through thanks
Posted : 07/05/2012 7:17 pm
I got mine direct from Superstar
A very speedy PDF in response to my initial email
Looky on their website
Posted : 08/05/2012 3:58 pm
Just remove the hub converters, they will come out but don't be to rough, then knock the bearings out.
Posted : 08/05/2012 8:56 pm
I had exactly the same problem - researched all over the tinternet and couldn't find the trick.
Luckily I was in Lincolnshire last week, so I popped in to Superstar's "HQ" - they explained how to do it and took out one side, leaving me to do the other.
The trick is that the "inner axle" is sealed by an O-ring at either end and this means that there's about 0.5mm of clearance if you press it down - they used a sharpened screwdriver to push this down. This then exposes the edge of the bearing that you can drive the screwdriver into and push it - and the end caps - out of the axle.
it sounds more complicated than it is - they took the brake disc off and then used a vice with soft "grips" to clamp onto the disc mounts. This means that you can use some proper leverage on the screwdriver to lever the "inner axle" to expose the edge of the bearing.
Hope this helps.
Posted : 08/05/2012 9:25 pm
[img] [/img] they will claim you broke the bearings use this
Posted : 08/05/2012 9:27 pm
