Hope evo hubs ,Can ...
[Closed] Hope evo hubs ,Can i fit a 10 speed casette
[#2578184]
I am running 9 speed set up with these but would like to put them on my other bike which is 10 speed, will they fit or will i have change anything...
Posted : 18/03/2011 8:28 pm
Short answer yes
Long answer yes, because the 10 speed cassette is designed to be the same width as a 9 speed.
Posted : 18/03/2011 8:48 pm
Cool! Thank's 🙂
Posted : 18/03/2011 9:09 pm
IIRC 10sp road cassettes are marginally narrower than 9sp, so you need a thin spacer at the wheel end of the freehub. Are MTB 10sp cassettes the same?
Andy
Posted : 18/03/2011 9:41 pm
If a spacer is required to fit the cassette it should come with it.
Posted : 18/03/2011 9:43 pm
IIRC, no, partly because I guess they're designed with compatibility with existing wheels in mind, but I'm not 100% certain.
Will have a go fitting tomorrow..
Posted : 18/03/2011 10:12 pm
No spacers with 10 speed MTB cassettes, it'll go straight on.
Posted : 18/03/2011 10:36 pm
That go for SRAM as well, given that SRAM MTB & road groups are purported to be cross compatible?
Andy
Posted : 18/03/2011 11:06 pm
Yep.
Posted : 19/03/2011 9:28 am
They fitted no bother,
Thanks for the info 🙂
Posted : 19/03/2011 2:38 pm
