Fox float CTD broke...
[Closed] Fox float CTD broken after 3 rides..help!
[#6821132]
Brand new bike - the lockout worked in the shop.
After three rides and gentle hose downs the CTD lever makes sod all difference. Seems to be open all the time. No lockout at all.
I have tried taking all the pressure out and then pumping back up - no difference.
Any ideas what I can do before I wheel it back into the shop?
Wally.
Posted : 29/01/2015 9:17 pm
Experience tells me that it's ronnied.
However, all isn't lost. You'll be covered by warranty, so contact your local dealer or failing that the bike's manufacturer/distributor in the UK. Chances are you'll be asked to send it to Mojo for a refurb.
If you're as lucky as I was, a certain explosive parcel company might lose the shock in transit and you'll be given a top of the line Kashima replacement fully tuned FOC...Happy days! 😀
Posted : 29/01/2015 9:25 pm
Bike is only 2 weeks old - but bought from a Major chain, so yes looks like I'm going back with it.
Posted : 29/01/2015 9:29 pm
It's not as bad as you might think...a warranty job is FOC and usually turned around very quickly.
Posted : 29/01/2015 9:33 pm
There is a very slight difference between the three settings - but is minimal. I know understand "climb" is not locked out.
Posted : 29/01/2015 9:39 pm
You do know that the CTD fork does not have a lockout . The climb setting has more compression damping but not a complete lockout .
Posted : 29/01/2015 9:41 pm
Mine turned out to be the remote lever.
Posted : 29/01/2015 9:43 pm
Mine has never worked. I keep meaning to get them sent off but it's been 18 months now!
Posted : 29/01/2015 10:13 pm
It's a rear shock - Front is prefect ! Oh dear should not have said that..
Posted : 29/01/2015 10:24 pm
they'll tell you that you've missed the first service interval which is after 12 minutes of riding and therefore the warranty is now invalid and a service will cost you £100.
Posted : 29/01/2015 10:28 pm
There's loads of difference between the settings on my 2014 CTD shock.
Posted : 30/01/2015 10:32 am
One delighted OP - Shock has been sorted by MOJO for free - and feels fantastic.
Posted : 07/02/2015 8:03 am
brakes - Member
I've had 2 CTD fails on mine, 1st under warranty and fixed, second out of warranty and fixed FOC. Completely happy with the customer support/warranty side of things from Fox in Oz.
Posted : 07/02/2015 8:12 am
Let all the air out, Move it up and down then re-pressure The shock, you didn't have enough air in.
Posted : 07/02/2015 8:18 am
Pitchpro - I did try that. MOJO used a service set on the Boost Valve assembly and 3 new valves. What ever that means. What I can tell you is that a floppy levered CTD rear shock went in with no difference between the settings and a positive clicking levered shock come out with a real difference between settings.
Posted : 07/02/2015 8:22 am
Mojo are very good in all fairness. Mine did this when my huge 24stone mate sat on my bike while it was in climb setting, it completely stopped working, a fellow rider suggested letting the air out and pumping it up again and it worked a treat. My lever has also broke and mojo fixed that and serviced it for free.
Posted : 07/02/2015 8:30 am
I do ride with a chap who likes his ale - note taken!
Posted : 07/02/2015 8:33 am
