DT370 rear hub (200...
[Closed] DT370 rear hub (2009 Anthem X1)
[#3426818]
The bearings and freehub on my Anthem X1 are clearly on the way out. A bit of googling seems to suggest that the bits will cost about £80 and DT say that I will need £100 worth of special tools. My LBS, from whom I bought the bike have been less than helpful - I took the wheel in for them to look at, and collected it a couple of weeks later, untouched and unexamined - they were 'busy' apparently.
If it's really going to cost me that much, I'll probably just buy another wheel - I quite fancy a pair of ZTRs. But have any other Anthem owners had to have their rear hubs rebuilt, and if so what did it cost?
Posted : 04/12/2011 11:04 pm
You don't need any special tools....some sockets (for pressing the bearings) a cuple of cone spanners and a hammer.
Theres only 3 cartridge bearings and one needle bearing (£4.99) in the whole hub!
I rebuilt one last week...2 bearings,needle bearings pawls and pawl spring and it was still less than £50.... with labour!
Posted : 04/12/2011 11:22 pm
Thanks for that. Where did you get the bits from?
Posted : 05/12/2011 9:20 am
My big tray of DT spares!!
You can order them direct from Madison via the ultimatepursuits site and delivered to your lbs.
They are listed as onyx spares iirc.
Posted : 05/12/2011 2:40 pm
I got these hubs on my Cannondale Rush, the front was great, the rear was pretty poor IMO. I had to remove the freehub every couple of months and clean it out, the seal was letting everything in. It just didn't feel right even after a bearing change so sold it on in the end and got good money for it. Shame really as it was nice and quiet unlike the Hope that replaced it.
Posted : 05/12/2011 3:27 pm
Great hubs. IME they seem to be shipped a bit short of grease when new and the pawls then fail. Since I have fitted new pawls and greased myself they seem to last a lot longer.
Posted : 05/12/2011 4:20 pm
 nikk
I got a new freehub for my 5 year old DT hub. The new freehub has a different spacer with a rubber seal to protect the bearing. May be worth ordering the freehub rebuild kit + new spacer, I got mine from Rocky Mountain Cycles.
Posted : 05/12/2011 6:36 pm
