Drilling out allen ...
[Closed] Drilling out allen bolts on discs
[#1901546]
I put a big ass crack in my Bontrager Earl rim today. So thats for the bin. Decided to strip it down and keep the hub and spokes and nipples and cassette and etc. Problem is that as I deconstructed it I found out that the previous owner has at some point rounded off 2 of the nuts holding the disc to the hub. What can I do? If I drill them out then the hub is for the bin, but at least I keep the disc. Can I get them out without damaging either part?
Posted : 16/08/2010 10:42 pm
cut a groove across the head of the bolt and use a screwdriver
Posted : 16/08/2010 10:43 pm
 mmb
try sawing a slot across the top to use a screwdriver or try gripping it with a pair of molgrips?.
Posted : 16/08/2010 10:45 pm
Yes. Drill them slowly with 8/10mm bit until the heads fall apart, then take the disc off. If your lucky, undo what's left with a set of pliers.
Phatman - Member
I am loving the simplicity of that. What to use to cut the groove?
 mmb
or drill a very small hole and use a very small screw extractor
Posted : 16/08/2010 10:46 pm
 mmb
use a mini hacksaw couple of quid from a diy store
Posted : 16/08/2010 10:47 pm
Had to do it on two bolts today!!
Dremel is your friend!!
Posted : 16/08/2010 10:48 pm
Hacksaw with a fine toothed bi-metal blade then?
Posted : 16/08/2010 10:49 pm
If you can get your hand on a Dremel than that will cut a very nice groove. Use the cutter disc first of all and then use it very gently to grind out a slightly wider groove.
Posted : 16/08/2010 10:50 pm
OK, cheers. I will begin the hunt for a dremel-weilding friend/companion/complete stranger. Wish me well!
Posted : 16/08/2010 10:56 pm
Try tapping a slightly bigger allen key or torx head into the rounded hole first. Its worked for me a few times.
Posted : 16/08/2010 10:58 pm
 pdw
Screw extractor worked when this happened to me.
Then use torx bolts when you put it back together so you don't have to go through this nonsense again.
Posted : 16/08/2010 11:00 pm
Tried - Failed
Sounds a most sensible idear
Posted : 16/08/2010 11:03 pm
A friend had this problem, we clamped the head of the offending bolt tightly in a vice and then rotated the wheel. It came off fine.
Good luck.
Posted : 16/08/2010 11:06 pm
 DT78
Try aralditing a allen / torq bit to it.
*you'd think I had shares 🙂
Posted : 16/08/2010 11:11 pm
Filing flats onto the opposite edges of the head so you can use a small spanner is more likely to work than putting a groove in for a screwdriver if the bolts are tight. Plus, if that fails, you can always try both...
Posted : 16/08/2010 11:51 pm
