Say longer than 80mm?
The trend for short stems would suggest that few do
yes but i got some funny salsa bars that remove about 20mm...
I've got a 120, 15 degree quill stem on my malt 1 frame? Why?
100mm Thomson on my SC Chameleon.
110 on my scott
90mm on my chameleon. i quite like a longish stem, if everything else is the same (i.e. reach) it means the wheelbase is shorter.
yup. 90mm is the shortest stem i've got on anything (except the bmx).
got a 140mm thomson in the shed if anyone wants it? form an orderly queue now...
110 on one bike, want to swap for a longer TT and a shorter one though. Other bike is 90mm. Both are full-on XC race steeds.
110 on my Intense - top tube isn't quite as long as the factory spec said it was
90mm here, keep meaning to try a shorter stem but worry it will make my bike feel too small.
100mm on my Epic
100mm on the DBR
110mm on the Iron Horse MkIII (std)
120mm on the salsa
I got an 80mm on the DMR, but haven't had a chance to use it in anger yet.
Really don't have a problem with them.
90mm is perfect for my Cham, wouldn't want anything shorter on it
hardly a trend, haven't had above 60mm since 1994
90mm on both.
It would seem I'm winning so far with 135
I'd suggest the sign of things having changed is the idea that 90mm is a long stem!
100mm on most, 90 on the single speed i think.
Feels fine with 100mm on the Orange 5
The 135 on my old Marin feels spot on, with the short rigid fork.
And the 100mm on my Sunn Exact feels right too, with the 100mm travel fork. Gotta match stem length to fork travel and front end geometry, innit!
Mostly run 90 or 100mm on my bikes although currently have a 80mm on the PA.
90mm here. Tried 70mm - it was too short and twitchy and put me too far over the bars.
120 with H-bars on my plastic Anthem
Shorter stem put you too far over the bars Scienceofficer?
Nothing less than 90mm, nothing longer than 120mm.
110mm on my on one
120mm on my Scale 30
115mm on my Scale 40
110mm on my Voodoo
Yeah I don't see how a shorter stem puts you too far over the bars?
40mm here
I've decided 85 mm * 10 degrees is perfect for me but theres only 1 stem in this size
90mm seems about right on my 100mm forked soul, and rigid forked love hate
- a shorter stem would I think speed up the steering, and the steering is plenty fast enough at the mo
i've got a 70mm on my heckler - but that has pikes and big wide bars
70mm on the 6-pack
70mm on the pace 305. Tried 90mm on it first but it felt like a barge.
90mm on the Tricross, does that count?
I think I started using shorter stems back in '98 when I bought a large Uzzi SL so I could get the reach I wanted with a 70mm stem. Cracking bike to ride (quite literally, went with quite a bang)
changes weight distribution doesn't it.
I think grumm means if your going down somthing steep a longer stem will make it harder to hang off the back of the saddle. I think you mean a shorter stem makes it feel like the bars are at your knees? (im 6ft+ and i know what you mean!)
I run 120mm on both my XC bikes (they are the same length) and 130mm on my road bike. Good for even weight distribution (ive got long legs so my saddle is quite far back) and handling is fine, even on fast twisty singletrack.
I had a 120mm stem (flipped to give -6 degrees rise) on my old on-one and secretly loved it
(not allowed one that long on the new bike, apparently it's been designed to do away with long stems, so the old girder is looking a bit forlorn on top of the fridge)
Usually over 80, but anything from 70mm to 120mm; given how easy it is to swap a stem, might put a 110mm for comfort on a long ride, or a short one for a bit more control when playing in the woods.
Yup but a longer stem is going to bring your weight forwards on the bike - 'over the bars'
It's only the mags that have decided anything over 70mm is "long".
90mm - the bike climbs perfectly, so no way I'm going to compromise that by using a shorter stem.
I've just gone shorter, to 90mm.
