Campag road levers ...
[Closed] Campag road levers with disc brakes
[#5053080]
Hi,
Has anyone got any experience of running Campag road levers with disc calipers?
I've got a pair of 2012 Campag Chorus 11 speed levers and wonder if they'll work with the likes of BB7's
Any advice and thoughts would great.
Posted : 10/04/2013 3:43 pm
Should work fine with the road version of BB7s - not the mtb version though.
Posted : 10/04/2013 4:14 pm
I do, with BB7 roads. They're spot on.
Posted : 10/04/2013 4:34 pm
I'll find out this weekend hopefully as I've got a lot of bits hidden in the garage that should miraculously turn into a Campag equipped disk road bike by Sunday night....
Posted : 10/04/2013 4:42 pm
That's great.
Just need to try and find an appropriate rear hub now that'll run a Campag cassette.
A quick search would suggest that DT 240's might be the answer.
Thanks for the info guys.
Posted : 10/04/2013 4:58 pm
I run campag 10 speed ergos with road BB7 or 5s. Also run a shimano rear hub with a campag spaced Ambrosio 10 speed cassette, such as
http://www.ukbikestore.co.uk/product/17/ambr317/ambrosio-10-speed-cassette.html
Only moved to 10 speed because of this. Not sure if anyone does a 11 speed version
Posted : 10/04/2013 6:27 pm
Having also looked into that, I'd suggest an ambrosio or similar to open out your hub options.
Posted : 10/04/2013 6:47 pm
Running 9 speed Veloce Ergos with road BB5s. Better than calipers, especially for feathering the brakes on the long twisty downhills that feature on a lot of my road rides in hilly South Devon.
I did have to change the cable outers to Jagwires to improve the braking performance as the original braking was a bit spongy. But with the BB5s set up properly and the new cable outers they certainly do their stuff 🙂
Running Campag gears with a 9 speed Shimano cassette on a FSA 130mm spaced cyclocross wheel. Couldn't find any affordable Campy compatable disc hubs. A [url= http://jtekengineering.com/shiftmate.php ]JTEK Shiftmate[/url] provides the necessary cable pull adjustment so the Campag shifters/gears works with the Shimano casette.
HTH.
Posted : 10/04/2013 7:33 pm
JRA built me some wheels with Hope hubs (and swapped the standard Shimano freehub for the Campag freehub as a no cost option).
In terms of other hub options, it gets fairly expensive - DT 350 or 240 if feeling rich, or Chris King new ones.
Posted : 10/04/2013 8:37 pm
Me too with 10 speed Ergos and BB7's. 1 wheel is Shimano and a Campag spaced Ambrosio hub, t'other is a Record hub with Campag spaced Ambrosio hub. Can't tell the difference. Actually the latter wheel isn't on the disc bike.
Posted : 10/04/2013 9:35 pm
Fwiw I'm using campag 10 speed levers with shimano everything else including a 9 speed cassette. The gear cable is fixed with the hubbub method which means it all works perfectly.
Posted : 11/04/2013 12:42 am
Hi,
Thanks for all the info, it's really appreciated.
After having a sleep on it last night, I have decided to sell my Campag and go for Shimano to open up my hub options.
Thanks again,
Andy
Posted : 11/04/2013 8:52 am
I'd suggest that you look at SRAM too in that case.
Posted : 11/04/2013 9:03 am
Thanks, will do 8)
Posted : 11/04/2013 9:10 am
