The house i live in has a burglar alarm, for the six months I've been here it's beem switched off at distribution board. When the fuse is switched it goes into an immediate alarm and asks me to enter code.... which the previous occupiers didn't know.
The power supply/control box has 'accent G4' on it. Is it possible to reset it and enter new code??
ta muchly
I don't have an answer, but it's "Accenta", not Accent. Might help your enquiries.
I was once told '1515' is a standard engineers code by an installer.
It hasn't ever worked for any other alarm I've tried it on but it's worth a try.
Only thing I've found online so far is this discussion.
http://www.avforums.com/forums/home-cinema-building-diy/1553600-house-alarm-accenta.html
May give you a few leads, I didn't read it in depth.
0000
1234
2012, 2011, 2010, 2009 etc.
1066
1515 belongs to the installer.
Depends who installed it as to what code it is.
hmmm may have a try, the street would appreciate that at half ten at night 8)
My PIN number is 6943, you could try that.
Almost certainly, but I suspect you'll have to pay someone from the Alarm company / an agent to come and do it for you. Personally, if I owned the place, I'd swap out the controller for a new one and keep the sensor infrastructure / wiring.
EDIT: If it's been disconnected for long enough the battery in the alarm unit will be flat, so you can disconnect that (which would normally cause it to go off, but with a flat battery it can't). Then put the fuse back in and try random combinations to your hearts content...
UPDATE! Finally got around to doing this....
Found installation manual on internet for my alarm panel. Switched it back on, put in default code and it reset it! It then wouldn't set because of a fault on front door, the contacts were too far apart, re-aligned them, changed the codes, some parameters and alarm works a treat.
Incidentally, I called a local alarm company and told them and they wanted £150 to come out and replace the panel and control unit 🙄
