Building a bike - w...
[Closed] Building a bike - what specialist tools will I need?
[#1788698]
I want to transfer bits from my current bike (Genesis Altitude 10) to a new frame (Cotic BFe) I've got a decent selection of 'normal' tools, allen keys, spanners, hammers(!) etc. etc., what bike specific tools do I need to buy, that I'm not already gonna have at home?
A BB removal tool...but what, specifically? I've got Shimano Deore hollow crankset/BB on the Genesis.
A chain tool.
Some wire cutters.
Is that it? What else do I need...any other incidentals that I should I order at the same time? What am I likely to find myself without during the build that is gonna hold me up?
Cheers,
Rusty
Posted : 11/07/2010 12:49 pm
Headset removal tool, headset press (you can bodge one of these together with a threaded rod, some big washers and a few bolts), BB spanner spring to mind. Given how infrequently you may end up using these things, might be best borrowing from a mate?
If the BB is HT2, you need one of these [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=3784 ]clicky[/url]
Posted : 11/07/2010 12:59 pm
You dont need headset tools .This can be done with a flat screwdriver to tap it out of the old frame and block of wood and a mallet to put it back in .You will need the right bb tool,chain tool ,and cable cutters ,or very good pliers will do
Posted : 11/07/2010 1:03 pm
Good idea to replace all the cables and outers when you transfer bits to a new frame due to differences in geometry.
Be prepared to 'play about' with headset spacers to find your riding position again.
Check that the seat pin and collar are the correct size (and yes... 0.2 of a milimetre is a significant difference so don't be tempted to 'nip it up tight and hope it'll be alright!')
Front mech (if you have one/intend to run one) is worth checking as-well for correct size and operation (i.e. top/bottom pull/swing). Similarly if you're not using a front mech but you are using a chain retaining device of some sort, ensure that it's compatible with the new frame and you still have the relevant components.
Might be worth getting the disk brake mounts faced as-well? Also check that your current callipers are compatible with the new frame.
Can't think of anything else to add to the above as far as tools go though...
Posted : 11/07/2010 1:11 pm
a set of allen keys, particularly 4 and 5mm. A torque wrench might be an option particularly if are using carbon components. you actually don't realise how tight you are fastening bolts as I thought when using one that it wasn't tight enough!!
Posted : 11/07/2010 1:14 pm
[url= http://www.google.co.uk/url?sa=t&source=web&cd=1&ved=0CB4QgwgwAA&url=http%3A%2F%2Fwww.ukbikestore.co.uk%2Fwl.aspx%3F3%26req%3D0-82f1&ei=ItI5TIiDAcL58Aa6p4ymBg&usg=AFQjCNFZ5_cMPFLJLR6MMKiHuByYx_osug&sig2=REYSkxfCcm2oL9LX4l6btQ ]Ice Toolz Toolkit 32 quid[/url]
Bargain and everything I needed, bar a headset press, which i got somebody to do for me
Posted : 11/07/2010 3:16 pm
Headset removal tool consists of a bit of copper pipe cut halfway down and spread in my toolbox lol
Posted : 11/07/2010 5:07 pm
Is it a brand new BFe? If so I'd get Cotic to fit a new headset for you, to save hassle and remove the fear of ****ing the headtube up. They do a Cane Creek S1 with fitting (when bought with frames from them) for only £25.
Posted : 11/07/2010 5:53 pm
 br
+1 new headset
Get a Hope one from your LBS and as a part of the deal have it fitted.
Posted : 11/07/2010 6:55 pm
yeh definately a new headset and leave the old one in the old frame if you sell or keep it. also if your getting LBS to do your head set, try and get them to face the brake mounts and take your bb out and fit on new frame if your not planning on doing it much and dont want the tools. again might be worth getting a new one depending how old it is as the HT2 BBs dont last very well.
Posted : 11/07/2010 7:16 pm
Should have mentioned; the new frame does have a fitted headset.
Thanks for the advice folks.
Cheers,
Rusty
Posted : 11/07/2010 8:54 pm
