boost frame none bo...
[Closed] boost frame none boost crank?
 D0NK
[#8294000]
Anyone using a boost frame with a none boost crank/chainring? [url= http://www.wolftoothcomponents.com/pages/boost-chainline-and-chainrings ]Wolftooth[/url] seem to think it's doable in many cases*. I'm thinking of running a none-boost direct mount ring on my cinch cranks, looks like there's plenty of room on my frame.
Anyone tried it?
*assuming I've read it correctly
Posted : 18/01/2017 6:41 pm
Its down to the frame / crank combo, but as a rule expect to get at least a 32T normal chainline on a boost set up.
Posted : 18/01/2017 7:24 pm
Yes! The boost spacing is more to do with adequate chainring clearance than chainline. Depending on individual setup chainline may actually be improved for the lower gears by using non boost cranks.
Posted : 18/01/2017 7:34 pm
I run a non boost crank on a boost frame.
A 32T oval is probably 1mm from the chainstay, so I could just about fit a normal 34T on there.
Posted : 18/01/2017 7:44 pm
 D0NK
sounds close, wolftooth say 3mm
That's what I figured, my current 32 boost ring is ~6mm from chain stay so a smaller 30t should have plenty of room
Posted : 18/01/2017 7:53 pm
We fitted some SRAM X0 GXPs to Abigale Enduro so we could standardised across all our bikes. Took off the new Race Face Aeffect. Had trouble getting the correct chain line. A Chromag zero offset was too far out and a One Up was too far in. Managed to get a 3mm boost SRAM direct mount ring which is now in the right place. Very difficult to find a 28t direct mount ring. Chromag do one but it's not been imported as yet
Posted : 18/01/2017 8:24 pm
 stuc
I'm running a non boost raceface cinch crank on a boost frame - Cotic Flare Max. It was built up with parts transferred from a non boost frame so I questioned this myself with shop. They said it's not an issue and as you've been advised in a lot of instances they felt it improves chainline. Ive not had any issues so far in a month of riding it.
I think one of the chainring manufacturers making cinch compatible rings also makes an offset one to 'boost' and non boost crank.
Posted : 18/01/2017 9:28 pm
