Bike FAIL.
[Closed] Bike FAIL.
[#3796733]
Not two hours ago, on a trail that meanders through Leigh Woods, Bristol, which many of you will be well acquainted, I experienced a strange sensation - you know the one ... where your mind is unable to correlate its contents in slow motion, but aware at least that something is not quite right. Hang on I know what it is I’M NO LONGER ATTACHED TO MY ...KING BIKE. In fact I’m hurtling through the air like a tw*t.
The below will be the reason why!
Is an ATB/Whyte warranty up to much? I purchased the bike in 2007.
Posted : 21/03/2012 10:34 pm
 hope
**** me!
Posted : 21/03/2012 10:35 pm
OMG :-O
Posted : 21/03/2012 10:36 pm
caused by not enough seatpost in the frame
Posted : 21/03/2012 10:38 pm
Root cause analysis = not enough seat post in that chap
How the hell did that happen?
 ton
what frame material?
dirtyrider - that's balls. I've been riding it like that for that last five years.
Posted : 21/03/2012 10:39 pm
and you wonder why it snapped 😀
Posted : 21/03/2012 10:40 pm
JRA (just riding along)
TMP (too many pies)
Posted : 21/03/2012 10:41 pm
owned it for 5 years, how much action has it seen? that qud link carbon is sparkly new
2 posts in succesion saying not enough seatpost 😀
TMP (too many pies)
that's ace
Posted : 21/03/2012 10:42 pm
We need evidence of the size of the rider before we start dissing the bike!
Posted : 21/03/2012 10:43 pm
Not enough seat post and too many pies, schoolboy error.
i'd have thought the seat post would have given up before the frame if it was the seatpost!
That seat tube looks sharp - good job it didn't impale you!
Posted : 21/03/2012 10:45 pm
It's seen a fair bit of action in fairness but I keep my bikes in good nik and generally ride my Cove HT in the winter.
Sympathetic crowd tonight then. 😀
I was lucky my gonads weren't left hanging off the top tube.
Posted : 21/03/2012 10:46 pm
Wouldn't have happened if it had been made of carbon.
Oh - and not enough seatpost in the frame.
Do you have a photo of the bike pre-breakage?
Posted : 21/03/2012 10:48 pm
nope. it's very possible for the seatpost to be below its min mark but the frame not able to handle the everage
Never mind
[img] http://i306.photobucket.com/albums/nn267/thedeluded/IMGP0136.jp g" target="_blank">http://i306.photobucket.com/albums/nn267/thedeluded/IMGP0136.jp g"/> [/img]
Posted : 21/03/2012 10:50 pm
FFS the seat post was just shy of where it broke - there was ample seat post. Someone talks cobblers then it spreads like wild fire in true STW fashion!
EDIT - cheers druidh
Posted : 21/03/2012 10:52 pm
400mm length post for me every time. I want at least 100mm of post below the top tube/down tube interface.
EDIT: but then I am a short-arse
ATB were great when my Whyte 19 broke after 18 months.
Blimey! Gutted for you. If it's any consolation my Raleigh Budgie snapped in half while I was riding it, the head tube just came away from the rest of the bike...I cried.
Posted : 21/03/2012 10:54 pm
Not enough seatpost and too many pies, I reckon.
Like we said, not enough post.
Posted : 21/03/2012 10:56 pm
Cool!
How much seatpost did it have in it? Do Whyte have an extra-long recommendation? Looks like at least 4 inches of post there.
Wonder which went first? Kinda looks like top tube? (seat-tube looks tear-ish, top tube looks crack-ish)
I'm "stocky" tis true ... but not that many pies!
deluded - Member
Exactly!
Does the seat tube have one of those fitted shims by any chance?
Looks like too many pies to me.
Posted : 21/03/2012 10:58 pm
a lot of bike companies give a minimum seat post insertion depth above which the frame will not be under warranty
exactly, there is a weld point and a lot of marginally braced tube with little support.
On the positive side, thats one less ugly bike on the trails 😉
Posted : 21/03/2012 11:07 pm
Your pointing looks fine but you need to sweep up them leaves off the wet decking; could cause an accident you know.
Posted : 21/03/2012 11:10 pm
I don't see why it shouldn't be a warranty job, as long as any instructions re insertion were followed.
Posted : 21/03/2012 11:12 pm
You have my sympathy! I would be p@@@ed off with that. Expensive bike no matter who or what is to blame. At least you weren't badly hurt!
Posted : 21/03/2012 11:17 pm
Seatpost inserted well below the seat tube/top tube interface?
Posted : 21/03/2012 11:22 pm
you can see the seatpost hardly went below the top tube at all
Posted : 21/03/2012 11:24 pm
Seriously do people think there was not enough seat post? There's nothing marked on the frame in terms of minimum insertion and I can't see anything in the supplied literature. As I said the post was just shy of where it snapped. It's no big shakes to me, I'll have to see what they say.
It inserted into the frame so far -
Posted : 21/03/2012 11:25 pm
Sorry - but that's a classic case of too short a post. It really needs to be well below that top tube/seat tube junction.....
Posted : 21/03/2012 11:27 pm
TandemJeremy - Member
POSTED 2 MINUTES AGO # REPORT-POST
It either did, or it didn't though. 🙂
Posted : 21/03/2012 11:28 pm
Rider weight limit circa 17 stone.
Posted : 21/03/2012 11:29 pm
I'd not ride a bike with that little post, couldn't you feel that flexing?
Seriously though I wouldn't, might just be me though.
Posted : 21/03/2012 11:31 pm
Still think op is in the right, as long as he followed instructions.
That post does look a little short
Posted : 21/03/2012 11:34 pm
It never flexed - and as I said I've had it at that height for 5 years. I thought there was adequate seat post but if not - you live and learn. Would it fail in that way though?!
Posted : 21/03/2012 11:35 pm
I wouldn't be sending that last picture off with any warranty claim if I was you
(I'd also lay off the pies a bit 😉 )
Posted : 21/03/2012 11:36 pm
There's got to be at least 12cm of post in the seat tube on your set up. I'd feel a bit aggrieved.
It's made me think twice about my own bike. I have 12.5cm of seatpost in the seat tube but it has a lot of seat tube projecting above the top tube.
Having said that I'm only 11 stone.
Posted : 21/03/2012 11:37 pm
Page 1 / 4
