Are SLX crank arms ...
[Closed] Are SLX crank arms hollow?
[#6560053]
Has anyone cut them open or had the misfortune to see the cross section unintentionally?
I'm looking at dabbling with super short cranks and as I have SLX cranks already, they look ideal to drill and tap further down the arm. From rough measurements this would give about a 150mm length. I would consider getting steel inserts too as I've noticed some models of SLX have them.
Posted : 16/10/2014 7:28 pm
Not so much but exactly the info I needed. Cheers.
Posted : 16/10/2014 7:45 pm
Zee's aren't hollow if you're after something to modify.
Posted : 16/10/2014 8:25 pm
Good call DD
Posted : 16/10/2014 8:32 pm
Zee are also heavy, Deore is lighter and is not hollow.
Posted : 16/10/2014 8:43 pm
Not sure there will be enough thickness left on a Deore to shorten to 150mm. Depends on the application I guess.
Posted : 16/10/2014 8:56 pm
I've got some old XT like the ones in the link it they will do. Just have shimano written on them as they are of a specialized.
Posted : 16/10/2014 10:19 pm
http://bikesmithdesign.com/Short_Cranks/hollow.html
Think I'll ditch the idea for shimano cranks!
Posted : 17/10/2014 6:40 am
