Bought some Deore XT cranks with one of the pedals stuck in them.
These ones, since you ask.
The usual “strip the pedal down and clamp the axle in a vice” trick didn’t work.
I had to resort to heating the axle, putting all the heat into the middle of the axle and letting it conduct up to the threads, rather than risk burning the paint and lacquer on the aluminium.
This meant I ended up bending the axle as I undid it, although I saved the crank.
A new axle is £30, but it seems there’s a bit of a reliability problem with them anyway.
So, will any other axle fit ?
Is it worth buying cheaper Shimano pedals just for the axles and swapping the bodies over ?
