Home Forums Bike Forum Xplr cassette with Rival 2x AXS
Viewing 11 posts - 1 through 11 (of 11 total)
  • Xplr cassette with Rival 2x AXS
  • Elbows
    Off for a big ride in the Alps and am looking for some easier gears on my Revolt.
    Is it possible to run a 10-44 Xplr cassette with a Rival 43-30 chainset? Current cassette is 10-36.
    jhpbk
    Is your Rival rear mech the Xplr version? As that would be the first stumbling block.
    Officially speaking Xplr is only supposed to be 1x, but ive ran a 11-40 cassette on a 2x system without a problem
    Your chain length on the extremities might need a bit of tweaking, but I can’t really see why it wouldn’t work.
    Elbows
    No, middle cage Rival.
    I will only run the cassette for specific rides, putting the 10-36 back on for normal duties.
    5lab
    I don’t think mid-cage rival can do 44t cassettes
    MSP
    I am running 2x with an xplr rear mech and cassette, has been flawless for me. Don’t think it would work if it wasn’t the xplr rear mech though, would be even better if sram allowed a bit more flexibility at which point on the rear cassette it moved the front chainring, then you might not even need the xplr rear mech.
    jhpbk
    In which case it 100% won’t work.
    You can’t run a 40T cassette on a standard AXS mech, nevermind a 44T
    You’d need a new rear mech, or at a push you could use one of the Derailleur Hanger Extension things. From Wolf Tooth or Sonder for example
    Elbows
    Does 1x mech work in a 2x system?
    crazy-legs
    No.
    Edit: more precisely – they’re not designed to and quite often won’t. However there are various tales on gravel forums where people have “persuaded” 1x mechs to work in 2x systems although it’s obviously not recommended or supported by SRAM.
    simondbarnes
    There’s even 2 people on this thread doing it!
    MSP
    Yep, and it didn’t take any persuasion, it just worked.
    I think that there is meant to be a little play in the rear mech jockey wheels on the 2x version, to help chain alignment.  I haven’t noticed any performance issue to not having that play, but I can imagine it will accelerate jockey wheel wear a little, which if you tend to not cross gears (something axs can help with) then IMO the impact will be negligible.
    slowoldman
    Do the fancy enhanced shift modes work with the XPLR rear derailleur?
