Well, that was interesting.
All went togehter ok and on the stand it required a bit of fettling to get the first two (largest) gears to engage properly.
As alluded to above it appeared not to like the extremes of the cassette, which stands to reason as I’ve also read about the 0.1mm difference per gear.
However with a bit of tweaking and very fine adjustment on the B tension screw, everything is working great with no noise in any gear.
Clicks right through the block up and down, either in singles, doubles or grabbing a handfull, and always lands in the correct gear. Never had this with 11 speed full shimano and a Sunrace 11 – 50 cassette and I’d say now it is 99%* as functional as the X01 but umpteen times more usable due to the ergonomics of the shifting options.
Didn’t even notice how good Shimano has it until I used something else, and it is such a good feeling on the bike going back to it. Such a small thing in the grand scheme of things but one that has brought inner peace back into my cycling.
* the 1% missing is not quite as solid a click as the X01 shifter and doesn’t distract from the performance.
A full ride will happen tomorrow and I’ll decide what happens then, as trail dirt / dust and bumps may alter the performance.
https://photos.app.goo.gl/eqAX6XsWgVwHVji57
https://photos.app.goo.gl/4Jw98PWJW44bNLdw8
