We got gifted a load of logs yesterday mostly softwood, been felled some time ago and stored outdoors not undercover, so pretty damp.
Set to cutting them down to length this morning and my dinky little electric Stihl absolutely wouldn’t touch them. 10 secs held in contact with the wood eventually caused smoke, but at best a 1/4″ deep groove.
Now normally I’d call it “blunt chain” but its only a few sessions old and the last time I used it (+/- a year ago) it was cutting perfectly (to the point I’ve not bothered buying sharpening kit yet). There’s no obvious signs of dulling on the edges of the teeth either. I have used saws with blunt chains before (my father-in-laws, mostly) and they usually cut, just slowly and without the nice big chips. This wasn’t doing anything.
I’ve always been a bit suspicious of the oil feed – it seems to block very easily and the chain was pretty dry, but for the 10 or so cuts I needed to make I couldn’t bothered to do a strip down there and then – could that be the culprit?
Otherwise – any ideas? Is it just the wetness? Did it with the bowsaw in the end…
Cheers!
