Hi all,
Just trying to understand the hearth regulations for a wood burning stove.
Most stoves we have looked at are advertised as only needing a 12mm hearth. However, on closer inspection of the regs, it seems this is only for freestanding stoves, not those in a recess / fireplace. Unless I’ve read it wrong, then it’s quite surprising as I’m sure many stoves are in a recess i.e. a fireplace.
Our fireplace seems unusual as the constructional hearth under the fireplace goes straight down in line with the recess and doesn’t project into the room at all. Not sure if a 12mm hearth is therefore permitted.
Confused.
