When I asked British Gas to install us a new boiler, I thought I’d be getting some quality work carried out. This was quite a few years ago BTW.
It has been a long, long succession of failures. If I had a gun I’d have shot them all by now.
Anyway, the latest issue I have is that I’m absolutely convinced the thermostat is a load of bobbins. If I turn it down, the boiler just carries on running away quite cheerfully heating the house up to the temperature of the sun. Quite often I have to turn it on and off, turn it down, turn it up, wait a bit and then maybe, it’ll work.
So I’m going to replace the thermostat.
Do any thermostats work or does it need to be aligned with the boiler in some way?
I quite fancy one of them thermostats with an LCD display, recommendations?
