Windscreen washer pump leaking, any tips?
Viewing 11 posts - 1 through 11 (of 11 total)
  • Windscreen washer pump leaking, any tips?
  • ed34
    Member
    My washer pump packed in so had to replace it, but now it’s dripping where the pump goes into the bottle. Pump just has a grommet over the inlet and that all pushes into the washer bottle.
    I’ve tried with the new grommet and the old grommet but still drips!
    Anyone got any advice on how to fix, might try lots of PTFE tape next to try and make the inlet on the pump a bit fatter so it squashes the grommet thing more.
    johndoh
    Member
    PTFE might be worth a try (as you suggest) or a decent think elastic band?
    Premier Icon bikebouy
    Subscriber
    PTFE, and maybe the small rubber gromit has been pinched and buckled a bit.
    phil5556
    Member
    Is it a genuine pump & grommet? If not there’s a good chance a genuine one won’t leak.
    Premier Icon finishthat
    Subscriber
    smear/splodge of silicone sealant after a good clean
    Premier Icon spennyy
    Subscriber
    Boss white will sort it, just don’t drink out of it after.
    ed34
    Member
    Thanks I’ll try PTFE and boss white as got some of that somewhere. If that fails ill get a genuine pump and grommet!
    sharkbait
    Member
    Self-amalgamating tape might be better than PTFE…. More thickness
    Put the grommet in the washer bottle first then put the pump in the grommet
    And as said earlier is pump and grommet genuine? If universal/after market might need to bodge it
