So you can look at the report and deduce what/how the engine’s been used. You could do the same for a car.
Ok but the point remains, what are you going to do with this information?
Most engines seem to outlive the car’s they’re attached to.
Take my OH’s utterly thrashed Fiesta as a prime example, it probably had about the hardest life you could conceive, doing years of a 3 mile commute, then years of a ‘fast’ motorway commute (she seems to view motorway speed limits as the minimum acceptable speed to be doing in the fast lane). It’s a tiny engine that’s been revved to death and frequently run with so little oil that the dipstick is dry. And the heater only works on 4, so over the winter it probably never actually warms up.
It’s had at least 3 MOT’s where the list of failures has been uneconomical relative to it’s value (i.e. where a sensible person might just have bought another one), even a set of branded tyres exceeds it’s scrap value, but it still soldiers on burning about 100ml oil/month on her 4000rpm motorway commute with a cold engine.
So the engine is still working fine, despite probably every one of those 145,000 miles being in some way “bad”.
Compare that to the saga of Molgrips Passat, which I get the impression is driven with a smidgen more mechanical sympathy.
