I wore the rim out on some cosign wheels from wiggle after 5 years,3000+ miles mostly commuting.
Which was fine, they had been light strong and cheap ish.
I found a DT branded rim which is the same diameter and bought new spokes. The old alloy nipples had cracked on lots of the spokes.
In sub 500 miles I’ve broken 4 spokes. One in the middle, one at the hub, two at the rim.
It’s a 28 spoke build. I’ve not changed weight much or changed routes at all. I’ve not got faster. I’m not carrying any more stuff on the paniers.
Is the spoke tension too high? I built it to what I thought was the same tension as the previous build. All I was going on was the rough note of the spokes and how squidgy they feel when pulled together.
Suggestions welcomed!
