Yeah, you built it the wrong way around. You won’t die but it maybe more vulnerable to going out of true in the future. Rebuilding wheels out of used and a bit grubby parts is less fun than out of new parts (esp spokes and nipples). If it was me I’d be redoing it now for peace of mind.
edit – hang on. I’ve looked again at Roger Musson’s ebook and following that you are def wrong. However looked at wife’s (factory built) bike sat here and it’s the other way around and if you say Sheldon specifies that way around you have built (never looked at his guide – is it still available, what a legacy that man left) it clearly makes sod all difference.
2nd edit – looking more closely at the picture – that’s a pre-used hub isn’t it? With it laced differently the first time. I think I can see the holes ‘stretched’ slightly differently from the first use. That’s a bit of a no no if I’m seeing it right. You should always lace to use the holes in the way their were deformed from first use when reusing.
