Recently put the tt bike on the turbo and rear shifting is out. Basically it works fine shifting down the entire cassette, but going up it won’t shift into top 3 gears. I need to go up 2 then down 1 to land in certain cogs
It’s etap so sticky cables aren’t an issue. When I’ve tried reindexing basically the issue just reverses itself and I can’t shift down on a few cogs.
I’m assuming it’s the hanger that is bent (don’t have a tool to check) as the mech cage isn’t hanging at 90 degrees to the ground. Should it? The thing that makes me question this diagnosis however is that bike has only done 20 miles outdoors, and never dropped. I also seem to remember the shifting working fine when I used it outside
The other thing im thinking is are the sliding dropouts causing the issue? As they are adjustable is there a chance that they are misaligned?
Any ideas as I usually find rear mech relatively easy to set up?
