Re: Larch – I had considered this but it would look massively out of place with neighbouring properties.
Why is that a bad thing? The best advice we took from our architect was to make our property stand out from the others. On the assumption that it’s mock tudor rather than actual, and you’re not in any conservation area, you should be able to do what you want. Personally I’m over the moon at the fact that we have next to no wood on the outside of our house, only a garage door that hopefully will get changed at some point this year. No need for any maintenance as all the windows are Al clad which also they can be in any colour you want.
Do what YOU would like with the cladding. Get rid, replace with composite, do it in neon pink if you like. Don’t be bound by what others might prefer.
