Those Waeco coolbox-style fridges are about as good as it gets for power consumption for a compressor fridge – something like 10-15 amp hours per day consumption (from their specs).
A small upright compressor fridge (50 litre or so) will use 30-40 amp hours per day.
Peltier cool boxes will use upwards of 100 amp hours per day.
Bear in mind that if you have lead-acid batteries, you don’t really want to be discharging them more than ~50% on a regular basis, so for a 110 AH leisure battery (55AH useable, say) you’d get 3-4 days from the Waeco, 1-2 days from the upright fridge, or about half a day from a Peltier box (no other consumption).
Obviously, if you can charge the battery at the same time (engine charging while driving, solar, or electric hook-up), you can extend these. Likewise, more battery capacity helps *provided* you have the means to fully charge it – a 50% discharged lead-acid battery will, very roughly, take a minimum of about 10 hours to get back to anything like full charge.
100W of solar gets you – again very, very roughly – 5 amp hours per day in winter and 50+ amp hours in summer (UK).
