• This topic has 7 replies, 5 voices, and was last updated 10 years ago by GW.
Viewing 8 posts - 1 through 8 (of 8 total)
  • What size C-spanner for DHX coil shock????
  • Premier Icon Dirtynap
    Hi all,
    I have lost my spanner for pre-loading the spring on my fox DHX coil shock. Can some tell me what size it is so I can go buy another one.
    Thanks
    Premier Icon steveh
    You shouldn't need a spanner to do it, hands only. You shouldn't have more than 4 turns of preload on the spring anyway.
    Premier Icon LoCo
    Steveh is right, any more than 4 turns and you run the risk of the spring becoming 'coil bound' bottoming out on itself (depending on weight/travel) before the shock bottoms out. This will quickly damage your shock, check your spring rate to see if you need a stiffer one to get the desired sag (25 to 33% of full travel usually)
    Premier Icon fivespot
    As both answers above. Turn the spring and collar together by hand, simples 😉
    I am 90kgs in my kit so according to spring calculators I need a 450lb spring with two full turns, which according to Fox is the max.
    TF say I need less then that though but still a 450 spring.
    When I measure the current sag its a bit more than 30% and ideally I want it at a bit below 30%.
    The problem is I have tendon problems in my left thumb and can't grip the ring well enough to turn it once its engaged with the pre-load ring. Hence I need a spanner.
    Premier Icon GW
    pipe grips will do it but will you be able grip them with your dodgy thumb?
    Ya spanners and alike are fine. never thought of pipe grips, duh
    Premier Icon GW
    oh.. and wrap a rag round the collar first.
The topic ‘What size C-spanner for DHX coil shock????’ is closed to new replies.
