• This topic has 206 replies, 18 voices, and was last updated 3 years ago by Drac.
Viewing 40 posts - 41 through 80 (of 207 total)
  • What is the point of hybrids?
  • 5lab
    Toyotas view on hybrids is interesting. There is a certain amount of battery manufacturing capacity at the moment. If you put all that capacity into 300m range cars you might get a million of them, but you could have 10 million phevs. The phevs will do a lot more miles on electric, and have a much larger environmental impact as there is so many of them.
    The mild hybrids exist due to ease. You just replace the alternator and starter with another box of similar size and attach a 2kg battery. Total cost is something like £200 but it drops the co2 by a gram or 2 scan make a difference (even work out cheaper than the penalties for the extra emmisions)
    TedC
    BEV’s more likely to weigh more (size for size) and they’re silent which isn’t massively helpful to cyclists and or the partially sighted.
    AVAS (acoustic vehicle alerting systems) requirements on vehicles should address the low speed Noise scenario, at higher speeds other noises are still present.
    jonnyboi
    There’s nothing wrong with the principle of PHEVs, I just think that the design and execution of some of them, especially some earlier models was cynical and flawed, and enabled by outdated official measures of assessment.
    And I’m not knocking them from the sidelines, we actually owned on and tried to use it efficiently. We now have a full EV and an economic diesel.
    twinw4ll
    I don’t know, there are 7 billion people on the planet and most are potential customers for a car, a hot tub, a 4000 sq ft eco house, a meaty lunch with excess calories, tech with all the consumption of electrical power and a what do want for Christmas bonanza.
    I have enjoyed reading all the blinkered above though.
    See you all in Hell.
    tjagain
    Thats the point. HYbrids make a miniscule reduction in overall admissions. its just fiddling round the edges. The only answer is to drive less – a lot less.
    Thats why its a greenwash. It allows folk to feel they are doing something to help the climate crisis but in actual fact it does nothing of significance.
    TheBrick
    I think the mild hybrid idea sounds like a good way toe gain some significant gain at low speed / start stop driving. If you could up the motor to. 72v pm motor I think this would work even better and allow to run the ICE at a more efficient load.
    For van and larger cars I can see a retrofit system with pancake motors on rear hubs to offer additional torque and low speed movement working well. It would all rest on the control system and battery / charge management.
    the00
    As that Harry’s garage video explains, they can be used to limit use of fossil fuels, or to limit use in built-up areas. They require a determined user to realize that, firstly by plugging it in, and secondly by switching to the correct mode at the appropriate time. They’re popularity is mostly from greenwash and a favorable taxation system.
    FuzzyWuzzy
    Surely it depends how the PHEV is used. If it’s just used a tax dodge and someone drives it 100 miles a day using the engine then of course it’s not going to be any better for lifetime emissions than a ICE car, probably even worse as you’re carting the batteries around.
    However someone that does 95% of their driving in sub 10 mile journeys, running entirely on the battery charge they go from plugging it in overnight then surely it’s a lot better in emissions-wise, even factoring in the generation emissions.
    Sure you could argue someone that does 95% of their journeys sub 10 miles should have an EV but we’re still transitioning from ICE and PHEV is a transitional technology. Once attitudes and infrastructure have caught up I’m guessing a lot of people buying PHEVs now will be buying EVs next.
    Sandwich
    Anything that needs to run an onboard engine to charge a battery no matter how sporadically is not an environmentally friendly device. It a fossil fuel burning machine not an electrically powered vehicle.
    Greenwash writ large.
    tjagain
    Depends on the source of the electricity but even if its fossil fuel electricity the total emmissions are less from driving – but that is countered by the increased emmissions from manufacture and disposal of the car. You are also lugging parasitic weight about – either the electric motor if driving under ICE or the ICE if driving electric. This wastes energy.
    You also get the particulates from tyre and brake wear – again increased because of the parasitic weight.
    TheBrick
    There is some quote about not throwing away the good in search of the perfect. They offer an improvement, it’s a journey.
    tjagain
    If petrol was £5+ a litre we would get far greater improvements in efficiency. after all we had 50+ mpg cars that could carry 4 adults in the 40s.
    The key is to reduce the total energy usage by reducing size and weight of cars and of course reducing how much they are used. Modern cars are bloated with huge parasitic weight
    Hybrids because people think they are doing their bit and because of the parasitic weight do nothing to reduce usage and energy consumption
    5lab
    and not forgetting the cost. My parents fit the model you describe – retired so spend most of their life pottering about locally, but occasionally do a 230m drive to see me or one of my siblings. They bought a plug-in hybrid – the full electric model was £20k more (xc40) and may not have been able to do the long drives in one hit – they didnt want the stress of not knowing they’d get there, which is fair enough.
    you generally get a lot less wear on brakes due to the regenerative braking. Most electrics offer one-pedal driving these days (as in, back off the accelerator and you end up with the car regenerating as hard as possible and slowing you down) – you can get around 0.3g of braking force that way which is as much as you want in day-to-day driving – you basically only need to use the brakes when someone’s messed up.
    Tyre wear will possibly be ever-so-slightly slightly increased due to extra weight but its minimal – an electric car may weigh 20% more than an ICE, which probably leads to 5% more tyre wear – lets say thats 5.25mm vs 5mm rubber over 25,000 miles – the amount being turned into particles is tiny
    molgrips
    Numbers or stfu
    nickc
    While there’s probs. a bunch of stuff you could take out of any modern car, I’d imagine a lot is going to be safety equipment though isn’t it? I mean sure, a Mk2 Escort was 875kg, and it’s modern Focus equivalent is 1200kg or so. But I’d bet 50p that the newer car is a bunch more safe and less polluting and gets better MPG than it’s predecessor. I know which one I’d rather have an accident in.
    edit: I’d even make the claim that even if say the Sat-Nav system weighed .5kg it’s still probably worth it for carrying an onboard system that directs you straight to where you want to go via the most economic route while avoiding traffic delays and using less fuel, over the lifetime of a car more than compensates for the extra weight.
    oakleymuppet
    Unless you are talking about SUV’s that weight is to make them safer. You’re making a lot of sweeping statements, are you an engineer?
    tjagain
    Look at the weight of say a golf in the 90s compared to now.
    cars are 50% heavier (ish) all that extra weight requires energy to move it and to manufacture it. the new model needs to be faster. so you add a more powerful engine. But then you need bigger tyres and brakes – more weight. etc etc parasitic weight. Hybrids require two engines – parasitic weight. Batteries – parasitic weight.
    Molgrips – the numbers are out there – how about you provide some for your outlandish claims.
    nickc
    So safety equipment, is that parasitic weight in your example? Have a rollover accident in the 90’s golf, and guess what, it’ll crush you, in the new model, you’ll still be able to open the doors.
    jeffl
    I live in a Victorian house, on a street of similar houses. As no one has drives then a PHEV or pure EV would not be that practical. The best we can go for is a Hybrid like a Prius.
    If people want electric cars to be mass market then central and local Gov need to do something about infrastructure. I’d love a pure EV car but it’s not practical. So I’ll soldier on with my 6 year old diesel Octavia for the time being.
    Hopefully in a few years time with autonomous vehicles we won’t have this concept of owning a vehicle, we’ll just hire one that fits the needs of the journey and does the driving for us. So small EV for driving in the city centre, big PHEV for towing a speedboat half way across the country.
    squadra
    Loads of hybrids used as taxi’s/private hire for short stop-start journeys in town where the benefits of lower exhaust emissions are most noticeable, and regenerative braking means that brake wear is lower. Not much seems to go wrong with Toyota hybrids and they often rack up big mileages.
    slowpuncheur
    We don’t need safety features though, right TJ? They give us a false sense of security which leads to complacency etc etc.. 😉
    molgrips
    My outlandish claim is that you don’t know what you are talking about. So you bring some numbers. I’ve said (which you’d know if you were reading properly) that we don’t know if the energy cost of the battery in a mild hybrid outweighs the increased FE and/or local air quality benefits. You’re saying that it does – so back that up.
    Golf Mk3 2.0 petrol 113bhp was 1035kg and is quoted at 32.8mpg.
    Golf 8 1.0 TSI petrol 116 bhp is 1264kg and combined fuel consumption on the new WTLP test of 53mpg and 49.7 ‘real world’ mpg on Honest John
    So it’s 22% heavier, roughly 50% more fuel efficient, and MUCH safer.
    Honestly if you’re going to wade in guns blazing you REALLY need to prepare your argument better or you’re just going to a) look like a nobber, b) get shot down and c) trash your own credibility.
    I had a 94 Passat for a while (as a second car) after owning more modern cars. I felt very vulnerable. My nose felt like it was on the windscreen, and the tiny little A pillars were noticeably very flimsy indeed, and close to my head.
    jimdubleyou
    Look at the crash test safety videos of a golf in the 90s compared to now…
    I suppose it would reduce the load on the NHS because 50% more accidents would result in a death at the scene.
    molgrips
    Indeed. Safety matters:
    The highest peacetime death rate was in 1966, when traffic was much much lower than it is now – anyone got a graph for that?
    oakleymuppet
    What we need is electric Citroen 2CVs – that will absolutely not lead to countless firey deaths from 40mph crashes at all.
    TheBrick
    2cvs are cool though so on balance…
    molgrips
    Cool from the outside, not when inside a moving one :puke:
    tjagain
    RThat is not what I have said. its easy to demolish an argument if you mischarectarise it
    what i said is any savings are insignificant because it does not alter behaviour thus energy usage is not significantly reduced.
    the answer to vehicle polution is to drive less. thats the only answer. Hybrids do not help as they givbe peiople a fig leaf to cover the fact they are still using massive amounts of eneregy to move a 1.5 tonne machine around to move one person
    Ok =- i am out of this. Its making me and others cross
    oakleymuppet
    In complete agreement but good luck with that post Covid!
    tjagain
    You really think all that extra weight is about safety? I accept a little bit is but the rest of it is extra equipment
    Imagine how much better fuel economy you would get in the modern golf was the same weight as the 90s one? Weight also increased wear and tear on infrastructure.
    molgrips
    Numbers please!
    Park a Golf 3 next to a Golf 8 – the chassis and frame on the latter are far more bulky, it’s clear to see that a lot of weight has gone into that.
    Then there’s a dozen airbags, big tyres, ABS and ESP kit, bigger brakes and so on. If we’re in the business of guessing, I’d guess that most of the extra non-safety gadgets on the modern car don’t weigh all that much.
    Imagine? Why don’t you have a go at calculating it?
    molgrips
    Also, if you want a modern car that’s light, get a Citroen C3 – similar size to the old Golf, and the basic 80ps version is 980kg. And fuel economy still around 50mpg.
    oakleymuppet
    Increasing the size of the crumple zones and intrusion protection on the front, side and rear added significant amounts of weight to cars. You won’t remove 300kg from a car by removing the speakers, satnav and aircon.
    To drop that kind of weight and keep the safety you’re talking about having carbon fibre safety cells in every family car and thinning the glass used using something like the automotive gorilla glass.
    molgrips
    To drop that kind of weight and keep the safety you’re talking about having carbon fibre safety cells in every family car and thinning the glass used.
    I dunno, as above Citroen seem to have managed it.
    oakleymuppet
    C3 only scored 4 stars in the crash ratings didn’t it – and it was outright piss poor for pedestrian safety!
    P-Jay
    I depends on the owner/user.
    For the Company Car driver, like diesel before, it’s taxation. It’s not their ‘fault’ taxation is this respect is supposed to drive good behaviour and the emissions tests are supposed to drive better emissions, but the manufacturers tailor them to the tests and not the best emissions – do we really think a 2300Kgs, 440Bhp Porsche Panamera hybrid gets 99mpg?
    It’s no different to the last gen of ‘Green’ cars, the super-eco Diesels, Company Car drivers seemed to love the Passat CC Bluemotion because the tax was cheap, it was supposed to do 58mpg, but most of the ones I saw got beat to death by their drivers.
    For the emissions conscious it’s a tentative, baby step towards a EV, if you do plug them in and you do drive well they can be very efficient and at the same time they don’t cost £50k+ and they will let you do that theoretical 1000+ mile journey people worry about. I might argue that if they really care about the environment, they’d be better of keeping the car they have in good shape for as long as possible and buying half as many cars and driving them half as often.
    They’re no longer a magnet for virtue signalling, people into that have migrated to Teslas.
    nickc
    Facts-schmacts You’re all missing the point; TJ has a new phrase…and that’s the important thing.
    I’m going to try to shoehorn “parasitic weight” into all my conversations from now on. I expect I’ll just win all internet arguments from now on with it as well.
    AD
    Looking at some of the comments I also think some posters are getting mixed up with hybrid types…
    A PHEV can be plugged in as well using its ICE to charge the battery. This is how I managed 1750 miles on 36L of petrol. Most of the mileage was using energy supplied by national grid.
    I do have some sympathy with the greenwash comment (mine is a company car so I fully admit tax rates are a factor).
    One point that hasn’t been raised is that, in my case, I actually drive it differently – I actively try to drive further before the petrol engine kicks in meaning I’m tending to drive more slowly.
    Maybe every other PHEV is never plugged in as the click bait stories say and I’m an outlier though.
    molgrips
    That’s not the car’s fault though.
    P-Jay
    Not sure it’s a fault thing.
    The point of them was to reduce BIK liabilities for their drivers, if VW really wanted to make the most environmentally sound Passat they could, they could have made it less powerful, limited the top speed, fitted smaller wheels and tyres etc etc etc, but they knew that it wouldn’t sell.
    Many of the drivers picked them entirely on taxation.
    There’s a argument, or maybe a stereotype that the very people who ordered the Bluemotion version were the last people to give much of a shit about emissions and frustrated by the Bluemotion aspects actually drove them harder. I know the reps that worked across the road from me at the time certainly did.
The topic ‘What is the point of hybrids?’ is closed to new replies.
