Meh…I’ve started laying some deckingat ‘home’, so i may as well do the right thing and finish it to a high standard…
Our sparkie put in a wire for some ‘low level’ lighting that’s switched from a ‘normal’ internal light switch – the cable pops out of a hole in the bottom (external) of the wall..
Most decking lights plug into a 3pin plug – however, as mine would be switched from a lighting ring, what sort of lights would i want to install?
I’d presumably want some without a neutral, seeing as it’s on a lighting ring rather than standard plug??
I”ll txt the sparkie in the am, but value the STW input!! X
DrP
