Home Forums Bike Forum What are the unbranded hubs on a Boardman?
  • This topic has 11 replies, 10 voices, and was last updated 4 years ago by feed.
Viewing 12 posts - 1 through 12 (of 12 total)
  • What are the unbranded hubs on a Boardman?
  • Potdog
    Freehub has loads of play in it so decided to whip it off and look at replacing it. Looked like a Shimano one, same cup and cone type, but a 10mm hex key is nowhere near the size needed to get the freehub off.
    Anyone had the same thing? Is it just a bigger hex key or a special tool job?
    Cheers.
    Northwind
    Some of the Formula hubs are like that. I think I bodged it with a big nut but tbh I don’t really remember, long time ago.
    Potdog
    Yeah, seems it could be an 11/12 or even 13mm hex. I’ll have to take another look tomorrow. Then comes the fun and games of finding the correct replacement 🤷‍♂️
    fossy
    Some undo from non drive side. My Mrs hybrid hubs need 12mm hex and from non-drive side.
    neilnevill
    I suspect something from Quando. That doesn’t narrow it down though
    jeffl
    I expect it’s a formula hub. I think they undo with an 11mm hex key.
    jezzep
    My Boardman had no markings on the hub but the axle says formula. They look formula to me.
    BR
    Jez
    sands
    It reads like you’re intending to repair your existing hub, but if it’s any help to you – a few years ago I replaced the supposedly ‘Formula’ hub on a 2014 Boardman Pro 29er with a ‘Deore XT M756’ on the basis of the info in this screen-grab.
    [/url]
    merk
    Even Boardman / Halfords struggle to replace them. They ended up supplying me with a whole new wheel under warranty.
    When the hub failed again, I just bought a DT Swiss wheel…
    Matt24k
    Changed mine for a Pro 4 using the existing spokes. Worth it for the comforting clicking/annoying racket.
    CountZero
    Beats using a bell on cycle paths!
    feed
    Shimano freehubs use a 15mm hex key. I searched everywhere online for one. No luck. Mate who owns a tool supply shop sourced one for me. I’d suggest bringing it to a bike shop for removal though. Prob not cost effective to buy a 15mm key (if you can even find one).
The topic ‘What are the unbranded hubs on a Boardman?’ is closed to new replies.
