Out on a club ride tonight and at one point my left shifter just wouldn’t shift up to the big ring. I assumed it was a cable issue and it was a hilly ride so thought I’d just carry on in the small ring and check it out when I got home.
After a while i put a bit more tension on (in line barrel adjuster) whilst dragging up a climb and it seemed to be OK. However later on the shifter wouldn’t spring back after a shift and needed an extra push. It then seemed to sort itself out.
Had a few pints post ride (club is at a craft ale bar) and walking home the shifter wouldn’t return normally.
Is this a common issue, I guess I’m thinking:
1) something stuck in the shifter
2) cable issue
3) shifter borked
Hoping for 1 or 2 really.
