I’ve been meaning to swap out my rear Sram Code RSC brake hose for a while as the one I had was a bit too short so I did it this weekend. When I took the hose out of the lever I realised that I’d over-tightened it previously and the olive was stuck.
I took the lever apart, knocked the olive out from the other side and rebuilt the lever all according to the instructions in this manual. The only thing I did differently was to reuse all the parts as I didn’t have a rebuild kit with a new piston etc. Bonus: my bite point adjustment had a load of grit in it which was preventing it from spinning so I was able to fix that.
I pulled what fluid I could out of the system from the calliper end then removed the old hose, fitted the new one with the banjo bolt from the old hose and then installed the hose to the lever with a new barb and olive.
Now I’m trying to push new fluid into the system and this is where I have a problem. It seems like there’s some blockage somewhere because I can push fluid into the lever up to a point but it doesn’t cause the syringe at the calliper to move at all. If I try to push fluid in from the calliper it’s as if I have the bleeding edge port fully closed (I don’t , it is open) and no fluid moves at all.
Does anyone have any idea what I’ve done wrong?
Things I’ve wondered it might be:
1. I have zip tied the new hose to the bike before filling it, is it possible I’ve done it too tight and squeezed the hose? I think this is unlikely but maybe?
2. Maybe I rebuilt the lever wrong in some way. I think this is unlikely because it was actuating smoothly and I was able to push fluid into it and feel it firm right up. I didn’t use all of the new internals that the manual says I should though so perhaps this is the issue?
3. Did I fit the banjo wrong somehow? Is it even possible to fit it wrong?
None of these feel like they’re likely to be the problem so I’m hoping someone else can see what I’ve done wrong!
