I asked this at the start of the season. Sadly I can’t make the nationals as I’m on holiday. I’ve had my best season ever winning an open and getting on the podium in most of the others taking the NE league title. For me the biggest gain was losing 5kg getting down to under 70kg for the first time in a long time.
For the last race of the season I bought a new bike. £2k but I won 😉
If that isn’t an option then I would suggest that anything now is going to make little difference unless you are going to spend a fair bit of money.
-Take off the bottle cages and the bolts.
-Cheap ebay carbon post and saddle.
-Lightest skinniest front tyre you can lay your hands on.
-Chop down some handlebars, remove the tape.
-Remove top cap and stem bolt (assuming star nut)
-Lightest 23/25mm tyre for the rear (you might need grip If damp and steep).
-Look at your gearing – you may be able to run a single ring up front so you can either remove the mech or at least all the cabling
-Put a new block on. I never used the 25t in hill climbs so could have got away with a 23t – depends on style and gearing.
-Shorten your chain – especially if you remove the big ring.
-Latex tubes.
-Weigh kit, you might have lighter shorts and jersey.
-Lose the helmet, watch, wedding ring, roadie cap, glasses, gloves, base layer.
-Take off your garmin – you won’t get the strava KOM anyway.
-Eat a low residue diet.
-Don’t be too hydrated for the race. It is only 4minute so you could be slightly below what would be normal for a longer race.
