Sorry – not had chance to update this thread, thanks for all the replays and help.
To answer a few questions:
Frame was bought directly from Commencal in August last year.
Malvern, Uk
Is the seat tube internally shimmed?
It doesn’t seem to be, looks to have failed at the weld then spread backwards.
Exactly, Ben, if that brace is functional, then the seatpost should only be required to be inserted below that. I do wonder in that case whether there’s a problem in translation…
I fear not, it took a week of emails, photographs and questions to get them to confirm the exact point.
So back to the question: if you use the post they supply, does it allow sufficient insertion(!) to support the size range they advertise for that frame?
They sell the bike built with a KS e-ten (100mm) Reverb (125mm) or a static 350mm post. Using the static post would only allow 10cm externally which IMO is nowhere near enough for a anyone in their size chart to fit a large frame.
I’ve written them a response that I’ll be sending over this morning – I’ll update everyone with their response.
