Evening all.
Hoping for some help and guidance.
Have had an IKEA kitchen wall unit for ages that was meant to be going up in a downstairs cupboard/pantry thing that I never got around to. Obviously I have a bit of time on my hands now.
As it was only one cupboard (60cm width) I didn’t buy the Metod rail so will be relying on the old methods of mounting, namely screw/bolt and the metal clip thingy.
Trouble is I have absolutely no idea what would be suitable to use and can’t go browsing B&Q etc now.
The cupboard weighs approximately 15kg and maybe need to factor another 10-15kg for whatever ends up in there.
Had a look on screwfix as they are around corner from work so could click and collect but lost in choice.
Going off the instructions it only indicates to use a flat bottom/pan head type screw/bolt.
The bracket is roughly 10mm thick and the wall it will be hung on is an internal side wall So ‘solid’. Guess that’s probably plaster onto breeze block or similar going of other walls around house though.
Would these do the trick?
https://www.screwfix.com/p/fischer-duopower-wall-plugs-10mm-50-pack/5424p#product_additional_details_container
https://www.screwfix.com/p/turbocoach-screws-zinc-plated-8-x-70mm-50-pack/3367g
Sorry that got a bit wordy! Advice greatly appreciated though.
Edit: it’s this cupboard and will be mounted as from page 13.
https://www.ikea.com/gb/en/assembly_instructions/metod-wall-cabinet-frame__AA-675946-4_pub.pdf
