So, new garage going up and I’d be lying if I said it wasn’t primarily a bike storage / workshop facility. My plan was to hang all of the bikes on the wall, and therein lies the problem…
In these modern days, sadly it’s necessary to lock bikes in a garage, even if it’s a secure one. I plan to stick 25mm of hard insulation on the wall, and then ply over the top secured to the brickwork with battens. If I were to use a normal ground anchor, it would have to be directly on the brickwork, which would mean it would have to sit in a hole cut in the ply / insulation, which being a couple of inches deep is going to make it something of a pain to get to.
So, question: WWSTD? How would you lock several (this is an imperial “several”, so best assume it’s quite a lot!) bikes on the wall so they are all secure?
