@crashrash- rotors and pads cleaned etc, still does it. Incidentally, this bike gets used on road a lot so i get the squealling brakes, I have sets of pads and rotors dishwashered, baked and sanded ready to rotate when the noise starts!
@mikewsmith- disassembled, all clean, no movement. Tried the pads and 2 other sets, no ridges, rotor is straight, tried another as well. The fork moves without any uneven patches, tried higher and lower pressure but no change to vibrations.
Put the old forks back on and it is now doing it with them too but not as bad. Brake line has an external mark where it was fixed to the 26 fork, [fixes higher up with the new fork] but I can’t see a kink externally. Is it time for a new brake line?
