Is the engine management light staying on? possibly to help diagnose with that model (it works with my DTI so may work with CDTI)
get in car – press down accelerator and brake – turn ignition to 2nd possition – after a few seconds the engine management light will start flashing.
You’ll need a pen and paper and a sharp eye…. theres will be flashes in sets, each set of flashes is one digit (10 flashes is zero). Count the flashes and jot them down to get 4 digit codes (there may be more than one).
Google the codes and see what that indicates (although there can be red herrings)
If there are no faults the light just flashes a few times then goes out
