Home Forums Bike Forum USB Hard Drive
Viewing 6 posts - 1 through 6 (of 6 total)
  • USB Hard Drive
  • paulosoxo
    http://www.play.com/PC/PCs/4-/6561128/Seagate-FreeAgent-Go-Portable-500GB-External-USB-2-0-Hard-Drive-Silver-ST905003FGD2E1-RK/Product.html
    Will this just work as a plug and play device? My work laptop is locked, so I can't install any software, however, I can back up to USB sticks, would this work the same? Can I password protetct it?
    cynic-al
    Aren't most external HDs PnP?
    Some Sainsburys and Morrisons have 250gB for £25 odd, am looking tonight!
    foxyrider
    You can run software off a USB stick/HDD – if you install the standalone versions of software like MSN messenger etc etc 🙂 YOu can't password protect it although you can get software to protect files by encrypting folers 🙂
    nickjb
    It is possible lock a pc so external drives wont work but it is uncommon and if a usb stick works then this will, too. I picked mine up from Tesco, the play one looks ok, though.
    paulosoxo
    Cheers all
    drofluf
    Depending on how your work laptop is locked you may not be able to install programs on a USB drive, you may only be able to store files on it.
The topic ‘USB Hard Drive’ is closed to new replies.
