Viewing 2 posts - 1 through 2 (of 2 total)
  • TV Network at home
  • mk1fan
    Second one from me today.
    Can’t find the thread (I think) I read last week where number and types of outlets were listed.
    Got to redo the home network due to poor install workmanship and poor requirement choices.
    I don’t have Sky at the moment but I wouldn’t like to exclude it later. I’m certainly not going to accept surface mount of cables if I do decide to get it. Access for cable runs and making chases is available.
    Can someone confirm (or correct me) that I need the following –
    At the ‘main’ TV point;
    A quadplex.
    A return aerial point (F-type).
    A secondary phone socket.
    Some data points – probably 4 as I’ll just fit another twin back box.
    At the ‘secondary’ TV points;
    The above minus the return socket.
    Or should I just make all the points the same as the ‘Main’?
    Milkie
    At the TV Main point we have one similar to this:
    I don’t see the point of adding returns to any other location. If you have a media server with TV tuners then add a return there.
    We used CT100 cabling throughout, along with a StarBox splitter/booster, it’s damn good! Also added Cat6 LAN cables and sockets. Two in each room and still a few things have to run off WiFi. 😯 Well worth doing.
The topic ‘TV Network at home’ is closed to new replies.
