Righty sold my ex511 rims (30mm internal) took the tyres off to reuse
Maxxis minion dhf 2.6 3c approx 3 months old (still loads of tred)
Maxxis minion dhr2 3c approx 4/5 months old (still loads of tred)
Using muc off sealant which has worked perfectly as far as I can see on the ex511…
So transfer all above (Inc new muc off sealant) to my new sc reserve carbon (again 30mm)
And the sealant is leaking from the bead on the rim on both wheels both sides… As soon as the tyre compresses in a descent it leaves 3 or 4 lines of sealant dribbling down the tyre from bead to tred… Clean off repeat for every descent
Now when I was putting some more pressure in the rear tyre I pushed in the sidewall to grip the pump.. And low and behold every time you depress into the bead area no matter where on the rim the sealant starts to seep out
Now these are brand new wheels, tape is perfect and they are holding air, the popped and banged on and the line is the same all the way around the tyre
So only thing I can think is the bead is somehow loose or something from my old rims(even though the same internal 30mm)
Its lost quite a bit of tubeless sealant due to this so can’t just keep wiping it away
Any ideas!?
