Towzer +1.
Punctures come in all shapes and sizes. In the early days of tubeless, I only had the little ones and found them under gunned for the purpose quite often.
The little applicator forks come in different sizes too.
The seal the punctures by being a tight fit. If they’re too easy to insert, they won’t so the job properly.
I’ve actually converted to only carrying the larger ones. I rasp the holes to a size I know they will fit instead of trying to fit the plug size to the hole. Takes the guess work out of the equation.
Another tip is to load one into the applicator in advance. Saves arsing about with gloves and filth when you need to use it.
