wheels developed a bad leak around the valve area. stripped the tyre, checked for holes, all looks good, set it up again with more milk but it just p1sses out from around the valve hole when inflated and wont seal up.
stripped it right back now, so taken the tape off as it was looking a bit tatty around the edges anyway. not sure what tape it is but probably gorilla tape, i never got on with the yellow stuff anyway.
ive got a bit of tape residue on the rims but ill scrape that off and lay some more tape on it.
ive had a good look at the wheel (all it says is stans notubes, no model as such) and its 21mm across the inside of the rim, where the tape goes. my question is, should i be looking at wider tape so it goes up the rim slightly? and if so what width would you recommend? gorilla tape still the best ‘ghetto’ tape to use? looks like i only need one wheels worth (2m) but if it makes sense ill buy longer in case i need to do it again sometime soon…..
any good videos for laying the tape? i know to stretch it as tight as possible but not sure about the best way of pushing into the sidewalls, just keep it central and push out as you go along? overlap the spoke holes either side of the valve hole and then a couple of stanley cuts for the valve to finish with?
thanks for your help, its been a while since i faffed around with wheels 🙂
