So, checked my old wheels out (cotic branded hubs, deep ish section rims) and they’re fine. The caliper clears the spokes easily.
It seems the alpkit hubs have a taller flange which brings the spokes out wider. The width between the flanges is also a bit wider.
My old wheels won’t do tubeless and I can’t be arsed with punctures.
For the moment it’ll have to be old caliper back on the front.
What to do long term? Either get a new hub built onto my front rim – what’s available with a low flange and disc mounts? What’s the cost of someone building a front wheel these Days?
Im still running sora 9spd which has suited me as I have an old 9spd 36 tooth cassette from an mtb on the back (9 spud is compatible both ways).
Id love to bury the gear cables under the bars at some point to tidy things up, do I take the opport7nity to do this now and get a whole new 105 groupset and hydro discs?
Any good deals about? What about just going 11 spd single front ring, what are my options with hydro discs? Is the sram system easy to get used to, I like the shimano shift/ brake combo.
