Saw these Fluxient mini U2 on eBay from Torchy, is anyone using one or able to recommend something similar?
I have one of those, and an older 900lumen Diablo, I bough the Fluxient/torchy to stand in for Diablo until I get the battery replaced as it’s now worn out, some thoughts.
– The Fluxient is slightly brighter (but new Diablo will be brigther again)
– The beam patter on the Fluxient is good, good bright centre for distance ‘looking’ as a helmet light, and the transition out to the rest fo the beam is smooth so although the centre is bright it’s not that spotty.
– The beam pattern on the Diablo is better, the spread is more even ande despite not being as bright or concentrated in the centre it seems to just be better, subjective I know but I prefer it.
– The Fluxient is heavier, not by much, but I started to notice it
– The runtime on the Fluxient with a decent 18650 cell is very good ~3hr, better than my Diablo was even when new
– The ability to swap batteries on the trail is very handy for me, whether this is much use to you or not depends on you use case though.
As it is they are both good, the Fluxient surprisingly so for the cost compared to the Diablo.
limited funds = Fluxient
can afford it = Diablo
but if the ability to replace the battery is a deal-breaker for you then the Fluxient is a very good option.
If they could do the Diablo but with a user-replaceable 18650 cell it would be amazing!
