The GF has just splashed out on her first full suss….
a Nukeproof mega tr in the sale.
It seems almost perfect for what she wants, the only downsides are it has avid brakes, that we will swap for shimano…
and its a single ring (Chainset: Truvativ Descendant 1.1 GXP, 170mm, 36t)
she currently runs a triple on the HT, and I cant see her coping with a single ring, none the less ive got a 32t to pop on for her to try.
If/when she decides she wants to change to multi ring set up, what do I need to know?
obviously I will need a front mech/shifter/cable, and new crankset…
I hear bad things about SRAM front mechs, can I fit a shimano front mech and use a SRAM shifter (so it matches the rear) without messing, or are we better just using a shimano shifter as well?
will any new multi-ring crankset just plug into the BB once I have removed the single ring crankset?
thinking, race-face/sram/shimano are they all cross compatible, or do i need a matching bottom bracket….
we could take it to a shop, but then we will never learn 😉
